-   -   Soldering irons (https://www.rctech.net/forum/radio-electronics/875279-soldering-irons.html)
ARB 05-05-2015 11:18 AM
Soldering irons
Back in the day the soldering iron to get was the Ungar iron. It appears that they are nolonger. What are some recommendations for an iron?
Tommy Nobrakes 05-05-2015 11:27 AM
I'll say it first...trakpower tk-950 is awesome. check this out too.http://www.rctech.net/forum/radio-el...ef-lesson.html Great read
Jerm13 05-05-2015 02:20 PM
+1. Had mine for about 5 years now. The Hakko is a good one as well.
http://www.trakpowerusa.com/solderin...950/index.html
ARB 05-06-2015 01:30 AM
Thanks guys.
Wildcat1971 05-07-2015 11:44 AM
Originally Posted by ARB (Post 13995638)
Thanks guys.
Hakko
bdhowardus 05-07-2015 12:25 PM
+1 on TK-950... I struggled until I got my TK-950. They are on sale on Amazon right now for $69.99. I bought mine off Amazon for $85-$90 I think. I think the TK-950 is just a repackaged Hakko.
Wildcat1971 05-07-2015 12:36 PM
it is, and the digital hakko is pretty close to that price range. Trakpower has a new digital station that looks pretty good also
kaiser 05-07-2015 12:53 PM
I love my hakko fx88. it's always the days it gets left home that I need it at the track and then have to end up borrowing someone elses burned up 40watt pencil. lol
uscgretired 05-07-2015 06:02 PM
I really like my Hakko!
jason w 05-10-2015 07:50 AM
Track power 955 digital station Is the way to go. Best product for the money for sure
ashxxx 05-10-2015 12:25 PM
track power irons are great makes life so much better and tower hobbies has them on 3 easy pay.
platgof 05-10-2015 01:17 PM
I don't like the hakko digital, and wish I had gotten one with a dial, as the digital is too complicated for changing temps.
ta_man 05-10-2015 06:14 PM
I actually still have an Ungar heater from when I was racing slot cars in the 1960s but the ceramic insulator is flaking off.
When I got into RC 14 years ago and started looking for a replacement, I found out that Ungar was bought out by Weller. So I started looking for something equivalent in the Weller line. I now use a Weller 4033S heater in my old Ungar handle. It is 45 watts and has a 1000 F rated tip temperature. Yes One Thousand degrees F.
I used all that heat back in the day soldering battery bars to build NiCD and NiMH packs. When I don't feel the need for quite that much power, I run it through the base that comes with the WLC-40 kit. It has a knob to turn the heat down. It is not a fancy electronic temperature control, but it does the job.
I have seen people using Hakkos and the like and none of the results I've seen compare to what I can do with the 4033S. It has a much bigger chisel tip than can be accommodated on a Hakko. There is plenty of heat capacity on that tip for 10 gauge and even 8 gauge wire.
Brian C. 05-11-2015 07:45 AM
+1 on the Track Power it is used almost everyday if not multiple times everyday at my local hobby shop.
snarky 05-17-2015 03:19 AM
I like my Goot PX201. Awesome soldering iron. It's like soldering station, but compact and light. Thermal control, replacement tips, 75W (i'm soldering 8-9mm connector, T-dins, 1/8 motor and other), heat cup, lead-free compatible. All-time in my pitbag :)
