Hobbyking xerun bec problem >
Old 04-20-2015 | 02:09 PM
Default Hobbyking xerun bec problem
Hello,I have a hobbyking xerun 120 a sensored system in my truck. I'm using a 2 s 5000 mah lipp battery and 8.5 turn brushless motor.When I put it under full load the steering servo moves by itself for a split second. What's up? Thanks, paolo.
Zippy2 is offline
Old 04-20-2015 | 07:10 PM
Yosh70's Avatar
What servo? You're on the right track it seems, BEC is not supplying enough voltage/amps to operate your servo properly. You can get a $5 capacitor and plug that into the aux.port in the receiver or solder in a Castle external BEC but the 1st suggestion should work for ya.
Yosh70 is offline
Old 04-21-2015 | 03:11 AM
B16A2's Avatar
Also what receiver are you running ? The XeRun 120A should have a 3A BEC, that should be ample to run a power hungry servo however if your receiver will brownout at a higher voltage you will see these issues.
A capacitor on the 6v BEC line will certainly help.
B16A2 is offline
Old 04-21-2015 | 07:56 AM
I have the same esc. I have to keep a power cap plugged in or the servo goes crazy.
Hw/hk upped the bec power on the v3.1 I believe.
2uzferunner03 is offline
Old 04-21-2015 | 08:35 AM
Where can I get a power cap? Thanks Paolo.
Zippy2 is offline
Old 04-21-2015 | 09:47 AM
Just do a search for glitch buster or power capacitor from whatever hobby shop/ online store you use.
Make sure to get one with the pigtail that plugs into a receiver.
Old 04-21-2015 | 10:48 AM
Yosh70's Avatar
Just get this one...does the job.
http://www.amain.com/rc-cars/spektru...-spm1600/p6570
Yosh70 is offline
Old 04-22-2015 | 01:13 PM
Thanks , paolo.
Zippy2 is offline
