Sanwa/Airtronics M12S
#451
Is anyone else getting advertisements and virus warnings on this site? They take over the Internet browser, so I have to shut it down. I'm on a Droid phone. This only happens on this site. Never on any other one
#452
Yes. I have to use this site on a pc. No idea why they are there
#454
Model Template?
What is model template? I have the 481 reciver and hobbywing esc. Know I can't use sanwa esc 1 and 2 templates. What does it do? Anything in 3,4, and 5 templates?
#455
Anyone know why my voltage reads 6.6 when its meant to be 7.2? im using a life battery with max volt set to 7.2, freshly charged
#457
Are you sure? a fully charged Lipo is 8.4v and Heres what google says and my charger also says 7.2 is full charge for a life battery "This is referred to as a “2S” pack, meaning two cells in series. Each LiFe cell has a NOMINAL voltage of 3.3V. A fully charged LiFe cell is 3.6V, and a fully depleted LiFe cell is 2.5V. Most LiFe chargers and balancing equipment are based using a battery's nominal voltage rating as a parameter."
#458
Im Just gonna swap it out when i need to cause i think the controller has a problem reading voltage
#459
Yeah it'll read higher voltage due to max charge for a few runs. The Life will then settle at about 6.6 volts for a time. When it starts to drop to, say, 6.2 volts, you only have minutes, maybe seconds, before the TX will go into low voltage shutdown.
LiFe don't drop voltage like Lipos. They ride at 6.6 volts begin to drop and then crash. Normal for LiFe.
#460
#461
Boost button question?
Let's say I want to run my electric car at 50% motor speed through the turns. Can I setup Sw3 in push button mode, so when I push it, I get 100% motor speed for the straightaway. As soon as I let go of Sw3 motor speed goes back to 50%. Something like a boost or electric NOS buttom.
#462
#463
Does anyone know what is the difference between changing the dual rate and end points?
#464
Yes, Its similar to sub trim and trim. EPA being sub trim and d/r being trim. Your dual rate is a percentage of your epa so you should set your epas to the max steering and braking but if you want to turn it down use dual rate cause its easier and you know what percentage it is
#465
Also D/R affects both left and right equally, while EPA has to be set separately.
