-   -   Fried my Mamba Max Pro (https://www.rctech.net/forum/radio-electronics/872886-fried-my-mamba-max-pro.html)
JohnPrz 04-18-2015 04:58 PM
So I fried my Mamba Max Pro running a 6.5 motor in my XB4 (1/10 4wd buggy) in sensored mode. Since the Mamba Max Pro can handle 6S, I assumed a small, lightweight buggy running a 6.5 on 2S would be just fine. No? Should I switch to something else? Unfortunately, Castle's website isn't real clear about the capabilities of this ESC in relation to low turn motors. Tekin for instance makes it very clear what the RS Gen 2 and the RSX can handle.
R1Joel 04-18-2015 06:47 PM
Continous problems with a Mamba Monster 1 then frying a Mamba Monster 2 was enough to turn me away from Castle for good. I switched to Hobbywing. I'd be making the switch if I were you to either Hobbywing or Tekin.
JohnPrz 04-19-2015 05:06 AM
I've had very good luck w/ Mamba Monsters and with the old green Mamba Maxx, and their small scale (18th scale) stuff has been bulletproof for me. Jury's out on the MMP for me. I just wish Castle would be more clear regarding their capabilities, but maybe that just reflects their focus on bashers and not racers.
hotrod87 04-19-2015 05:48 AM
I have always has good luck with castle stuff also. Only fried a sct (bought used worked once) and an sv2 ran in snow and totally my fault. I believe there is no limit on the mmp for motor. I have even ran 4s with it in a slash 2wd and the 3800kv 4 pole geared to the moon. Having said that seems about 50/50 for peoples luck running them but the bec seems the weak link.
JohnPrz 04-19-2015 09:40 AM
I'm wondering also if the MMP can handle high voltages but not high amps. A 6.5 on 2S would generate pretty high amps.
dan_vector 04-19-2015 10:08 PM
It should be able to handle the setup you had. I've seen loads of castle esc's blow up. Personally I've had 2 XL2's go on me. Won't use castle again personally. I now use Muchmore speedos in my onroad stuff and tekin in my offroad stuff. Never had any of these fail.
JohnPrz 04-20-2015 04:52 AM
I had an RX8 catch fire once. But yes, for me its either Tekin or Castle ... both US based companies.
RC Juice 04-20-2015 08:25 AM
I personally believe Castle makes some quality products, and when I first got into electric RC many years ago (after many many years in nitro) I used a lot of their products. While I still think they have great motors, I did have my share of their ESC's which went up in smoke which were being used in applications which were well withing the capabilities of their ESC (I have also thought it odd how they do not list specific specs for their products). Having been on forums for many years as well I can definitely say that there does seem to be an overwhelming amount of "My Castle ESC Burnt Up" stories out there. I've gone to all SkyRC products (TS120 on my race rigs) and have been very happy with the performance.
JohnPrz 04-21-2015 04:11 AM
Spoke with a Castle Tech. Turns out running a 25C battery with 4mm banana connectors (small point of contact) with a 6.5 isn't a good idea. I'll be upgrading my battery and connectors.
Exojoe 04-21-2015 09:33 AM
I run the Castle mmp in everything from comp crawler to 10lb scaler to tekno 1/8 ebuggy and tekno 410 sct. I have found that they run better with the 3.2 firmware in them. It's iffy whether they like the newest firmware or not. ALL of my MMP's also have a CCBEC to help them out.
