Nosram comet hd
Old 03-30-2015 | 08:30 PM
Default Nosram comet hd
Nosram comet hd does cooling fan come on as soon as it's switched on or switch on via temp. got one and fan not working cheers
jay m is offline
Old 03-30-2015 | 08:44 PM
Should work when switched on.
I would not use it when it's not running. Measure the output from the fan port with a multimeter. Should read around 6V (I thought).
Do not run it unless your run a 13.5 motor or something. Otherwise you can seriously damage the esc. Have seen it happen few times with a LRP Flow Works (=Nosram Comet)
Govert is offline
Old 03-30-2015 | 08:53 PM
Thanks mate thought that was the case
jay m is offline
