Weird problem,need advice.. >
Old 03-17-2015 | 11:56 AM
  #16
Hitokiri_2000's Avatar
If you get a Sanwa system you will be one happy camper!
I actually do belive the MT-4S is 2S LiPo compatible. Well you can without any problem use a 2S (2cell) LiFe battery in your car as they do not fry anything. But remember if you do chose to go with the LiFe option to get a digital charger that can charge Lithium chemistry batteries. Another thing to remember is to get a battery with as many mAh as possible.
The more mAh the longer runtime you get.
I forgot to link to an accessory you would need if you are planning to get the charger i linked to in my previous post.
This will come in handy
http://www.hobbyking.com/hobbyking/s...apter_Set.html
And should you get some 2S LiFe or LiPo packs these will be good to have as well
http://www.ebay.com/itm/10pcs-JST-XH...item2eb807c817
Last but not least one of these can save your home from going up in flames when charging lithium chemistry batteries
http://www.ebay.com/itm/RC-LiPo-Li-P...item3a94543734
Just ask if there's more that pops into mind.
Hitokiri_2000 is offline
Old 03-17-2015 | 12:01 PM
  #17
enem178's Avatar
You've pointed me in the right direction and its much appreciated!
enem178 is offline
Old 03-17-2015 | 12:29 PM
  #18
Anytime mate anytime.
Old 04-03-2015 | 02:08 AM
  #19
So...
Have you received the WR-4401's you ordered yet?
Old 04-03-2015 | 12:09 PM
  #20
enem178's Avatar
So...
YES! I'm really happy with the servos! I really appreciate your recommendation!
enem178 is offline
Old 04-03-2015 | 01:34 PM
  #21
Glad to hear it, I like to share what I belive is awesome.
A quick tip, if you experience brown outs, then get a good external BEC, one you can program. Like the Castle Creations 10A BEC.
I put one of those CC BEC's in my Durango DEX408 V1 after I had installed an Xpert WR-6601HV servo.
The RX simply browned out, when I turned super rapidly, from side to side at max angle. (Not something one would do while driving of course) But still I like to be on the safe side, so nothing will interrupt the power to the servo as it is now.
I set the output from the BEC to 8.4V, which is what the WR-6601 is designed to handle as it's maximum operating voltage.
Old 04-03-2015 | 07:07 PM
  #22
enem178's Avatar
Will definitely keep that advice in mind. Again thx a mill!
enem178 is offline
Old 04-03-2015 | 11:44 PM
  #23
Glad to be of help.
