Case for Orion Advantage Touch Duo >
Old 02-21-2015 | 11:07 AM
Default Case for Orion Advantage Touch Duo
I am looking for a case to put the Orion Advantage Touch Duo charger in.
Any suggestions?
Thanks!
sstriano is offline
Old 02-21-2015 | 11:44 AM
dan_vector's Avatar
Hudy have some pretty neat accessory cases out now in different sizes. Probably one of those would be very nice as a charger case!
dan_vector is offline
Old 02-21-2015 | 12:16 PM
Dan.J's Avatar
I just picked up a KuduCase on Atomik RC a couple weeks ago, AWESOME quality and can get about any size you want, the bigger ones are not cheap but will last a lifetime. They have the pick and pull foam so making your stuff secure and protected in them is easy.
http://www.atomikrc.com/pages/search...q=kuducase&p=1
Dan.J is offline
Old 02-23-2015 | 04:51 PM
Suspended
if you have a harbor freight close by, $29 alum case full of foam http://www.harborfreight.com/18-in-x...9318-8538.html
it's actually decent quality. hinges are good, handle is good, latches are working good still I can't complain. been using it for 2 years straight.
the dividers will not stay in place all that well. but I put shoe goo on them and they don't come loose anymore even with 3 4s batteries hitting against them.
mtpocketsracing is offline
Old 02-23-2015 | 06:43 PM
apriliamille's Avatar
look at the progressiverc.com cases. they have charging decks and various odds and ends to do things to the cases with
apriliamille is offline
Old 10-05-2015 | 11:20 PM
I transport my Duo around in a Cabela's ammo dry storage box that sells for $14.99. Or better yet, buy 500 rounds of bulk .223 PMC ammo and get a free dry storage box. The Duo charger fits in this box very nicely without kinking your balance board or charging leads.
Also gives you some extra room in the bottom for all things electrical in nature (wires, connectors, heat shrink, solder, esc programmers, etc..)
http://www.cabelas.com/product/PMC-B...Box/735146.uts
sporto is offline
