Charger options
Old 02-11-2015 | 12:36 PM
Default Charger options
So I just got back into the hobby after 20 years and in past I have never dealt with lipo batteries. I did my homework, but I have some doubts about the set up of the options. I hope to find some help here.
Balance speed (slow, normal, fast): is there any preferable setup or can I set it up to fast?
Balance mode (CV phase, storage voltage, always): same as for balance speed. Is it better to set it up to Always? Especially when storing the batteries?
Trickle: what is it?
Discharge reduce: If I understood correctly, with this option I can reduce the discharge value that I set up. But why would I like to discharge a lipo battery more than its storing value?
kloss is offline
Old 02-11-2015 | 12:52 PM
DRTMI's Avatar
Super Moderator
Do you already have a charger? If so what charger are you talking about?
DRTMI is offline
Old 02-11-2015 | 12:59 PM
thunder 620 charger 300 watt 20 amps
kloss is offline
Old 02-11-2015 | 01:22 PM
DRTMI's Avatar
Super Moderator
Just guessing here but, I would use normal for balance speed. Have no idea what the balance mode is, sorry. Trickle is for Ni-cad - NiMh batteries.
DRTMI is offline
Old 02-11-2015 | 01:25 PM
Thank you!
Any idea what is lipo termination? With a range value of 4.00V-4.30V
kloss is offline
Old 02-11-2015 | 02:10 PM
DRTMI's Avatar
Super Moderator
Where it stops charging. Set it to 4.2V.
DRTMI is offline
Old 02-11-2015 | 02:29 PM
Suspended
My new batteries came with instructions not to charge below 1c. So if you have a 6000mah battery it needs to be charged at 6 amps min
mtpocketsracing is offline
Old 02-11-2015 | 02:58 PM
k, thanks. But isn't the lipo voltage 7.4V?
kloss is offline
Old 02-11-2015 | 03:21 PM
Dan.J's Avatar
Yes a 2 cell lipo is 7.4V but end voltage on charger should be set to 4.2V because they are talking per cell and a fully charged 2 cell lipo should come off the charger showing 8.4V (4.2V's x2) Its a little confusing.......set end voltage to 4.2V per cell and your good to go.
Dan.J is offline
Old 02-11-2015 | 03:25 PM
Dan.J's Avatar
I usually charge at 2 to 4c myself but I honestly can't see what charging lower than 1c is going to hurt at all other then taking a long time to charge? Could be something to it just can't think of any reason why it would hurt a battery
Dan.J is offline
Old 02-11-2015 | 03:31 PM
Got it. Set and forget
kloss is offline
Old 02-12-2015 | 05:22 PM
Suspended
I don't know but the sheet with these (smc racing) says not to go less than 1c. all i have is a 50w charger and it can only put 3amps in to a 4s battery. so I've been researching a new charger.
Old 02-12-2015 | 08:01 PM
Yep I read it too. I would stick with those numbers. No less than 1C and no more than 2C.
kloss is offline
