DX4C Problem
Old 01-22-2015 | 07:57 PM
Default DX4C Problem
I just got a DX4C and the SRS4120 that was included. Binding and throttle calibration seemed fine. Whenever I try to run the thing my savox 1258tg servo just randomly turns on its own. Is this a scenario that a glitch buster would typically fix? Any other idea on what the deal might be? I opened a support case a SpektrumRC.com but though I would check here as well.
Thanks.
tilimil is offline
Old 01-22-2015 | 11:14 PM
Yosh70's Avatar
Yep, weak BEC from the ESC and power hungry servo's both contribute to that.
Its usually the three manufacturers Spektrum, Castle and Savox that dont get along.
Glitch buster (capacitor) should fix that up.
Or if you can adjust the BEC output on your speed control, that will probably work as well.
Yosh70 is offline
Old 01-24-2015 | 04:07 PM
You need to bind and calibrate twice .
First time set steering and end points on controller , after turning off reset settings on trans to zero for that car ,
Then re bind and just calibrate .
All should be good now , avc will work properly and you will then be able to use trans for any fine tuning you may have .
strykerakamack is offline
Old 01-24-2015 | 05:48 PM
Glitch buster (capacitor) should fix that up. Savox are notorious for brownouts
Triplec4 is offline
