Disabling AVC - any tricks?
I have a DX4C and I'm having trouble disabling AVC...
Instructions say to install a second bind plug in the disable port which I've tried and it doesn't seem to work. Ive left the bind plug in the disable port, which seems to disable it but after turning the ESC back on it seems to reengage it. Ive tried a few different combinations but so far nothing works... any tricks? Cheers |
One way to just be done with it for good would be to pick up a sr410 receiver and sell off your srs4200/4210. You should break even or even pocket a couple of $$s
Other than that, the bind plug left in the disable position and/or dialing the values out on the transmitter should work. |
I was under the assumption it was all done with the transmitter... Either way I did it under the AVC tab on the transmitter and believe it to be not effecting my vehicle
Originally Posted by highace10
(Post 13781336)
Originally Posted by RobsRacin
(Post 13781679)
FYI, at least one reason it can't be completely disabled from the transmitter is for racing, rules generally forbid any electric driver aids. If it was only tuned off at the transmitter it would leave doubt if it was turned off during the race. Requiring the binding procedure removes most suspicion.
| All times are GMT -7. It is currently 04:10 AM. |
