-   -   Powerlab 6 problems (https://www.rctech.net/forum/radio-electronics/854604-powerlab-6-problems.html)
Teejay88 12-30-2014 06:26 PM
Powerlab 6 problems
2 Attachment(s)
Well just got my batteries in today so i was going to try out my powerlab 6 with the power supply i got to power it. turned it on the fast charge set the charge to 10.0amp set the discharge to 10.0amps then started after about 5 minutes i was scrolling through the menus and found that is says my dc power supply is only do 12.1v at 2.5amp, something i did must be wrong. please help and thanks to everyone
Yosh70 12-30-2014 08:37 PM
I just checked mine (have a converted server PSU as well) and it read 12.8V @ 6.8A charging a 2S 5000Mah at 10A. What does the charging screen read? Are you at least getting a 10A charge rate?
And is that a good tight connection to your power supply?
Teejay88 12-30-2014 08:46 PM
No charging rate showed 1.99 when I set it 10amps I just tried it again and it actually worked at 10amps another question when it asks for discharge rate what should I put it at
Yosh70 12-30-2014 09:02 PM
I use high power mode for the most part and as far as discharge goes, I dont usually change that in any of the charging modes except storage charge. 10A is what I set it to altho my 4/5S lipos dont get anywhere near that.
What do you mean, "No charging rate showed 1.99?" I dont follow....
dski 01-30-2015 05:40 AM
Not sure if you are stuck still, but two things....
Use high power charge mode. You caN change it but fast charge has a setting that limits charge amps.
Second, the screen you show is how much power you are pulling from your power power supply.
