Tekin RS Gen2
If the Gen2 RS is 120 amps, then that is more than plenty to power a 6.5 motor. It must be the lack of a fan, so I am wondering if anyone has added one, and did they use the switch wires to run it?
The esc doesn't have a heat sink to be cooled by a fan and so adding one probably wouldn't make much difference. Besides I didn't think the gen 2 is 120a more like 90a. I certainly can't find anything written down by Tekin which confirms this...
the thing with the rs, is that it is small. add an internal/external heat sink and a fan and it will really loose that good feature.
Strange... Both of mine are still perfect with hundreds of runs on them in 2wd buggy. Do you clean them/the car with any solvent based products that could make the plastic brittle? Just I've been there and done it myself...
Brake clean will do that in a heartbeat. Don't let even the tiniest bit of overspray get on it. I know, I've done it. Fortunately replacement cases are available and easy to change.
Yes, its a good thing replacement cases are available as I have already replaces one because of this cracking... Now it looks like I'll be doing it again soon
