Battery Question
Old 11-16-2014 | 08:42 AM
TheRcKid17's Avatar
Default Battery Question
Ok so my 2s Lipo was not charged for awhile, so i decide to try and charge it. My charger said the batteries were at a full charge and only lasted like 4 minutes in my qual then cut out. Today i decided to try and discharge them and try to charge them again. My charger said they were at 6.4v and I tried charging them back up and it went straight to 8.4v. Is this my charger or battery i am so confused.
TheRcKid17 is offline
Old 11-16-2014 | 10:07 AM
Hoese37's Avatar
Sounds like it may have a bad cell. Try to use a friends charger to see if it causes the same issue. If it does then it is the battery, if not then its most likely the charger.
Hoese37 is offline
Old 11-16-2014 | 02:16 PM
wingracer's Avatar
I've seen a bad connector do things like this. It's probably the battery or charger but couldn't hurt to check that out first.
wingracer is offline
Old 11-17-2014 | 05:58 AM
skeasor's Avatar
I have a Venom 2S lipo and the balancing wire has a short in it. I have to wiggle the wire a little bit because I'll get a "CHECK VOLTAGE" error.
skeasor is offline
Old 11-17-2014 | 12:24 PM
if your charger doesn't show each individual cells voltage try using a volt meter on the balance connector to read the cells. Sounds like you have a dead cell. I did have a venom 2s lipo that sometimes would cut out for no reason though and i replaced the deans end and it seemed to fix the problem temporarily. They replaced the battery under warranty and haven't had problems since
jtomas24 is offline
