5 cell hump pack question >
Old 09-16-2014 | 06:06 PM
GAJ
Questions?? 5 cell hump pack question
I have purchased a used nitro R/C. It has a 5 cell pack. Each battery in the pack says 1.2 V 1000mah ni-mh. I cannot make out the manufacturer.
With a multi-meter, how do I know if the pack is good?
Voltage is at 6.2
Electronics worked when purchased after a quick 5 minute charge on a "quick charger"
GAJ is offline
Old 09-17-2014 | 12:26 AM
xrayracer1's Avatar
5 cell packs whether they're flat or hump packs have a minimum voltage of 6.0 volts. So 6.2 volts means the pack is ok.
xrayracer1 is offline
Old 09-17-2014 | 06:07 PM
GAJ
What should the voltage be fully charged?
How long should the recharged battery last while powering throttle and high torque steering servo. Tough question I know, but I have no idea.
GAJ is offline
Old 09-17-2014 | 07:38 PM
Just get a new pack if your that unsure about it. Make sure you have a failsafe if you do decide to use it. 1000mah really isn't much and won't last long anyways, maybe 10-15 mins on a used pack depending on the amount of power your servos draw.
2uzferunner03 is offline
Old 09-27-2014 | 01:54 PM
GAJ
Me again...
Cell pack is reading 6.6V, but servos only work for about 1minute. Afterward, pack still at same voltage. Swap in my 4 x 1.2 rechargable AA's and all is good for a long period of time.
Is pack dead? Is there a way to test?
GAJ is offline
Old 09-29-2014 | 03:15 PM
That's how every nimh battery I've ever had ended it's life. Voltage okay but no oomph even of you get it to take the rated mah.
