Speed Passion ESC compatibility? >
Old 09-02-2014 | 08:20 AM
Default Speed Passion ESC compatibility?
I have a HPI club racer with a the speed passion stock racer ultra sportsman 17.5r motor + esc combo. For some reason, my motor stopped working. no damage (barely used actually). it just doesnt turn. I've verified the esc & the receiver are connected correctly. The receiver still works correctly as the steering responds. When i press the throttle on the transmitter, I do see the esc light blinking / reacting to the throttle input.
Maybe I need a replacement?
I'm ok buying the newer competition 3.0, 17.5r motor as long as it works with the ESC. Or would it be better to buy a new esc + motor combo? Any ways that I can battery wire the motors to confirm if its the motor and not the esc?
Thoughts / suggestions? car is not raced, and I just realized I have parts for a full aluminium replacement as well.
dazed1 is offline
Old 09-02-2014 | 08:38 AM
MarkA's Avatar
Before you do anything else, try a new sensor cable.
MarkA is offline
Old 09-02-2014 | 08:45 AM
Good idea. Is it pretty much any sensor cable or specific to the ESC + motor ? As in do I have to find a speed passion sensor cable?
Edit: as in, would this work? http://www3.towerhobbies.com/cgi-bin...?&I=LXCPCW&P=7
dazed1 is offline
Old 09-02-2014 | 08:49 AM
MarkA's Avatar
Any sensor cable will work. I've had good luck with the TQ brand ones lasting the longest, just make sure you get one long enough for your application but not so long it becomes a tangled mess on the car.
MarkA is offline
Old 09-02-2014 | 09:23 AM
Thanks. ordered one. Should be here before the weekend. lets see how it goes.
dazed1 is offline
Old 09-03-2014 | 11:41 PM
Good piece of advice Mark, came to my mind as soon as I read Dazed's question but you were so much faster D let us know later was it the cable.
Wrynn is offline
Old 09-04-2014 | 06:51 AM
I should be getting the cable in mail today. So hopefully I'll know soon. Hope thats what it is, would be a cheap fix compared to a new motor
dazed1 is offline
Old 09-05-2014 | 06:54 AM
Nope. Did not help .
Put in the new cable. had the battery charged. The wheels turn, the esc recognizes that the throttle is pressed (red light goes away), but no motor movement. blah
dazed1 is offline
Old 09-05-2014 | 04:26 PM
Pauly6401's Avatar
Have you checked the end point adjustments/throttle settings on your radio? Sometimes if they are turned down too far, the radio won't send the signal to your ESC and you'll have reduced or no speed. Also, if you somehow accidentally reversed your throttle settings on the radio that could do it.
Pauly6401 is offline
Old 09-06-2014 | 07:24 AM
Yup. checked the throttle, made sure its not reversed or set too low. chrged the battery too That might be my only other thing, battery is about a year old and not run during that time.
dazed1 is offline
Old 09-06-2014 | 09:29 AM
Pauly6401's Avatar
Yes, either test the battery in a different vehicle and see if it does the same thing, or try a new battery. Is it a LiPo or NiMh?
Old 09-06-2014 | 10:02 AM
Its a LiPo. Will try my other battery before i head to the LHS
dazed1 is offline
Old 09-06-2014 | 03:45 PM
No go with a new battery too
Time to go to LHS or hobby town and see if they can help figure it out.
dazed1 is offline
Old 09-06-2014 | 07:20 PM
I went to Hobbytown and the guy said its most likely the motor is bad. He said usually if you try to turn it, it should turn (without any power), and if you try to short 2, it should move a bit (?)
So anyways, I'll be emailing speed passion. The ESC has a blinking red (low voltage) and a steady orange.
Thoughts on what replacement motor I can get? I believe the ESC will support anything upto a 9.5
dazed1 is offline
Old 09-06-2014 | 11:42 PM
The blinking red is telling you the esc is in stock mode ( blindly mode)
kimbo13 is offline
