-   -   Radio failure (https://www.rctech.net/forum/radio-electronics/829515-radio-failure.html)
21missions 08-09-2014 08:34 AM
Radio failure
My controller only works when almost roughing the cars antenna.
Any ideas how to repair.
ElectricMann 08-09-2014 08:51 AM
check receiver antenna is it broke.also what radio and rx is this ? if broken repair or replace rx.
stoney452 08-09-2014 06:57 PM
I had a small crack in my antenna near the open where it comes out of my airtronics receiver. I called Airtronics and talked to the tech support guy and He told me could send it back in out I could replace my antenna with a new wire that I had on my work bench. He also told me that the antenna had to 190mm long. I cut a piece of 24 gauge telephone wire that I had and unsoldered the old one and remove the potting on the pcb board. I instert the wire soldered it up and put a dab on shoe goo on it and works like gold. michael
ThePanda 08-09-2014 07:33 PM
Interesting fix that I will certainly note.
