Please help
yesterday i had a pretty big crash, i hit a curb and it made my ESC come un-taped from the chassi and one of the ESC cords came un-plugged from my motor. i plugged everything back in and re taped the ESC down. today i go for a run and when i hit the throttle my car chugs and makes a screeching sound. i picked up my car and held full throttle and it cuts in and out. also my motor gets super hot after 5 secs of holding full throttle. please help me with this thanks.
Everything is stock. [ this is my 1st RC car] Car: RC10T4.2 Motor: Powerful Reedy 3300kV brushless motor ESC: XP SC500-BL Brushless i can make a video if you guys need it. any help appreciated thanks :( |
If there is smoke with the motor it is possible that it is shorted. The esc could be damaged too, and is sending a skewed signal to the motor, causing it to run badly. Check gear mesh too.
Cheap rtr electronics usually don't last very long, and it is possible that it has just died, especially with the large crash. |
it still works. goes as fast as it did since the day i got it, its just now it makes a weird noise and sometimes cuts in and out. does that mean it still could be shorted?
Originally Posted by GarrettZ
(Post 13455093)
Second do You know what wire came off. As in a battery wire or senor wire. Did you try to recalibrate the esc. These are some thing i would check out. |
as i said im new to the hobby, so i have no idea on any of those things. you guys think if i took it into my local hobby shop they would know what the problem is? im pretty lost when it comes to these things since im new :/
and for the wire the came un plugged. there is wires. red,yellow and black. and it was the black one that came un plugged. |
It has a slipper, but gear diff. Those should be fine. It isn't sensored either.
Try uploading a video. Diagnosing electronics issues concerning the motor are hard to do without visuals. |
ok ill make a video right now
sorry for the video quality. you can see how it chugs and dosent do anything when i have it full throttle. i have to keep tapping the throttle to make it work
anyone?
The gear mesh sounds really right. Try backing it off and trying again.
check rear axle nuts loosen then tighten again ..look to see if you broke a bearing .... also as said in upper reply GEAR MESH is to tight..
thanks for all the help guys! i took it to my local rc shop and they helped me. it was my spur gear. it got grind down so i had to buy a new one. simple fix. i thought it was going to be much worse. thanks for all the help though :)
| All times are GMT -7. It is currently 05:56 AM. |
