Turnigy metal gear servos from HobbyKing
Are they good? The price is unbelievably low compared to say, Savox!
Some of them buzz very loudly and twitch at what passes for center on them. Others will swear they work ok for the price but if you're looking for savings, servo, tx and rx are the last places I'd look for savings and are therefore, the last items I'd be buying from Hobby King. HK = Batteries maybe, basher stuff maybe, servos no.
I picked up one of their Bluebird HV servo's for my buggy and altho slightly noisy, it centers good, has way more torque than I need and fast too. I've only had it for a couple of months but so far its been excellent.
For $61 + shipping, you get a HV, digital, coreless, titanium gear anodized servo (made in Taiwan if that matters) with 388 oz/in of torque and speed of .10 sec. I run a Castle 10A BEC with it and IMO, its one the best deals I've ever run across.
The upper end of the bluebrid servo range are nothing to sneeze at, they've been making servos for an eternity, and produce re-branded servos for several other manufacturers - turnigy is not one of them though.
If buying servos from HK, i'd steer clear of the turnigy servos in favour of Bluebird servo's, great servos for the price and perform just as well as servos costing double or more from other mfg's.
Sorry, should have been more clear - I was making reference to the upper end std size vehicle (high torque/HV/$) turnigy servos and not the crappy low end stuff - the decent spec'd turnigy servos are not rebadged bluebirds, looks to be a mix of Power HD and Power XQ.
Not that there's anything wrong with a Power HD or Power XQ servo (which I ran previously at one point). The HV and high torque metal vented case bluebird servos are superb for the money, well made and reliable. These are the ones I use and will only ever use from now on:
http://www.hobbyking.com/hobbyking/s...0_14s_74g.html
http://www.hobbyking.com/hobbyking/s..._10ec_74g.html
They are just as good and reliable as more expensive offerings from Hitec, Futaba etc from my own experience, and at half the cost.
But depends on what servo and price range the OP was talking about.
It's kinda ridiculous that I can recognize all these brands just by case design and sticker placement.
True, but I was just making the point that there are also some cheaper rebranded servos that are good like this http://hobbyking.com/hobbyking/store...13sec_52g.html which is obviously a Bluebird
and this Power HD http://hobbyking.com/hobbyking/store...6kg_12sec.html
and this Alturn USA servo http://hobbyking.com/hobbyking/store...g_0_09sec.html
This is true. Not sure why they're doing that.
Plenty of companies hire out OEM's. HK just happens to sell stuff as well.
Could do worse.
HK sells Power HD servo's as well....maybe they're in kahoots.
So Turnigy copied a Taiwanese company design? Hard to believe.....
Um, no? Alturn USA is an actual OEM. There's a difference between rebranding and copying.
Yes.....yes it is.
