-   -   ESC Glitch buster question.. (https://www.rctech.net/forum/radio-electronics/825632-esc-glitch-buster-question.html)
WEAVER 07-18-2014 04:19 PM
Got a question, I have a mamba max pro, and I am wanting to run a glitch buster with it, I bought a racers edge glitch buster that plugs into your receiver, but I only have a 3 channel receiver in this vehicle, and when I run the transponder all the spots are taken.
My question is, can I solder the positive and negative wires on the glitch buster to the positive and negative battery wires on the esc so that I don't have to plug it in? Will that work, or is that not how it works? Just curious, thanks..
Dave H 07-18-2014 04:24 PM
No that's different, where the typical power cap goes. The glitch buster needs to go on the BEC side of the ESC. Usual solution is a Y servo harness, something like this:
http://www.e-fliterc.com/ProdInfo/EF...FLRYH3-250.jpg
WEAVER 07-18-2014 04:29 PM
Thanks. I think I answered my question, I was reading where you can supposedly plug the glitch busters into the bind spot on the receiver and that will work just fine. Then I would have enough spots open. I'll give that a shot, didn't even think about that.
Dave H 07-18-2014 04:30 PM
Or the battery slot, that should work too.
Yosh70 07-18-2014 04:31 PM
Do you have a bind port free on the receiver? That should work....
EDIT: Ok, you found that out...good.
WEAVER 07-18-2014 04:32 PM
Thanks Dave. And Yosh.
