Sanwa MT4 - RX-461 Binding HELP!!!
Hi I just got a Sanwa MT4 with RX-461 for my HPI Vorza. I have properly bind the radio to the RX-461 and I can steer but CANNOT throttle. I shaved off the default HPI servo to fit into the receiver which works perfect. I also bought a KO Propo 30106 servo which I will later shave.
I switched the ESC plug with the servo. So the servo went to throttle and ESC to steering and it worked BUT obviously the throttle on the radio acted as left/right and the steering on the radio did forward/backward which is obviously dumb.
How do I fix this issue? The Blur ESC just keeps blinking red. According to rogerhobbycenter castle ESC troubleshoot the red blinking light on the ESC means:
1) ESC not calibrated.
2) Radio on partial reverse or
3) ESC is on full reverse.
I checked and re-checked the radio and its all on ZERO. I mean there is a huge LCD on the radio that tells me that there isn't any input.
Any ideas? Am I doing something wrong?
Suspended
Trim switch number 2 (TRM 2) around the outside of the wheel should be your throttle trim. Just click it until you reach 0. You should also go into your menu and check your sub trim and make sure it's zeroed out also on the throttle channel. Menu item number 10 labeled TRIM has your trim and sub trim adjustments.
Suspended
Hey i did +60 on the throttle trim so that the ESC would stop blinking. So if i drop the trim to 0 its gonna do reverse. The +60 is the throttle neutral point. How to i set the trim to 0 and not get my Vorza to move?
