Trinity D4 17.5
#136
![Default](https://www.rctech.net/forum/images/icons/icon1.gif)
This is the unit I use. It gets the job done.
http://hobbyking.com/hobbyking/store...h=watt%20meter
#137
Is this the same kind of product? http://www.amain.com/product_info.ph...ch-Power-Meter
I'm not risking an order from the hobby king overseas warehouse. Amain for the win.
#138
![Smilie](https://www.rctech.net/forum/classic_images/smilies/smile.gif)
#140
Any way you could post a vid or step by step instructions on how you are doing this? I see you posted earlier to just remove rear wheels but have seen others mention removing pinion and free reving. I just ordered the same meter you are using and plan to test all of my motors for ideal settings. Thanks.
1. First I hook the meter up in line between the esc and lipo. Always use a fully charged battery.
2. Next you turn on the esc and radio
3. Then with the motor installed in the drive train and wheels removed apply full throttle untill the amperage peaks.
4. make adjustments if needed to reach your desired setting and retest.
#142
Unfortunately I cannot try the D4 tonight. Trinity sent me a new sensor board and so far, the motor is performing well. I put a high torque 5% rotor in as well. I am vert excited to try it.
#144
with my 5% torque rotor i started at 35/72 in my B5M and ended up at 36/72 with about 63-65 degrees timing on the can. also running a fan on it. comes off at about 150-160.
#146
i had no problems clearing any of the jumps on our track. when i tried 35/72 i went as high as about 70 degrees on the timing, but at that setting it cogged at low speeds, came off hot and lost too much on the bottom (but was VERY fast on the straight). so i wouldn't go any higher than about 65 degrees on the timing (for those that don't have the motor, the last marked line on the can is 60 degrees).
#147
#149
Should I wait for this or get a killshot for my B5rm? will be running 17.5 on clay.
#150
avg. 1415-1430 from 2 5% I purchased. I have a off the shelf 12.5 torque under 1400
Ive had better luck with Fantoms Pro select rotors. Two I bought had way better numbers than the 5% I tried.
I have been running Fantom equipment for about 2 years and have not been disappointed yet.
