Help: Testing Equipment >
Old 06-16-2014 | 07:31 AM
Default Help: Testing Equipment
Hi there RCtech forums, this is my first post and I was wondering if anyone here could tell me what the cheapest and most time/cost effective method for testing various ESC's is, please?
Hopefully this explanation will help - I have a wide array of various Castle brand ESC's such as sidewinders, hydras, mambas, etc. They're all used but I want to test which ones still function properly.
I tried selling them without testing at first when I assumed that if they looked fine they must run fine. I was wrong. I am a newb to everything RC related so please be very specific and gentle with me.
So basically I have various ESC's.
What parts would I need to test them and how would I actually connect and then test the module?
cyfeariul is offline
Old 06-16-2014 | 08:08 AM
howardcano's Avatar
The most expedient way would be to put them in a car and run them. Do you have all of the equipment available to do so?
howardcano is offline
Old 06-16-2014 | 08:20 AM
lbenton's Avatar
If you have a program card or USB adapter you can attach it and feed it the latest firmware, that can get you about 90% sure it will be fine when you re-sell it. But the only way to tell is to put it and do a lap or two, or at least bench test it with a motor that is in spec for the model.
To test you need:
1 - receiver / radio
2 - compatible motor, something like a 17.5 brushless motor will test any sensored motor without drawing more than the ESC can handle. Sensorless as well but may cog.
3 - of course a charged battery
4 - servo - optional to bench test the ESC, but will in some cases expose a weak BEC issue.
This will also mean a lot of soldering practice as well.
lbenton is offline
Old 06-16-2014 | 03:12 PM
The combination of "I am a newb to everything RC related" and "I have a wide array of various Castle brand ESC's" seems odd.
Why did you acquire the ESCs?
Dave H is offline
Old 06-17-2014 | 05:00 PM
Originally Posted by lbenton
+1
To test you need:
Could I use alligator clips for the connection to skip soldering? I do have soldering experience as part of a hobby but thats all.
So these program cards work for all ESC's? Is there a specific one I need or will any of those cards work? Also, if any card works which card would you recommend? Thanks!
Oh, and as for the other option, doing a lap or two. What would be the cheapest most efficient RC car (which I assume comes with all the separate parts you listed?) I could buy to get the job done? When I say cheap and efficient I mean cheap but not so cheap that it breaks in 30 minutes.
Again, I really appreciate the help!
Old 06-17-2014 | 10:27 PM
asc6000's Avatar
Clips are ok. They do not have to be run on a track to see if they work. You do not need a car to test them. Each brand of esc will need a seperate "box" which would cost more than some esc's are worth. If you don't have any interest in running rc cars then all your time and money are being wasted. You won't be able to resell them until you can gaurantee they work, are you willing to do that? buying a car and testing them is a dead end.
asc6000 is offline
Old 06-18-2014 | 12:14 AM
I think they are all the same 'brand'. Castle brand. I'd also like to test some motors, also castle brand.
What do you mean by "box"? Assortment of gear?
Old 06-18-2014 | 06:43 AM
racer1812's Avatar
Super Moderator
+1
He appears to know little to nothing about R/C yet has all these esc's and motors he want's to test.
There's nothing wrong with being new but I smell a rat.
racer1812 is offline
Old 06-30-2014 | 02:55 PM
Originally Posted by racer1812
+1
I dont have any diabolical intentions, I'm just a guy that works for a guy who ended up with a box of used Castle ESC's.
I need to find a way to test them so he can sell them. I figured the guys here on forums like these gotta know the best, cheapest, quickest way to do that.
On the other forum I'm posting the only guy replying is telling me that I should buy a Traxxas Bandit and use that as a test machine.
He also said I might need different batteries if I have lots of different ESC's.
Is all that legit or can it be done for cheaper than the likely $200 the Bandit would cost?
Old 06-30-2014 | 03:28 PM
EddieO's Avatar
A servo tester, motor(may need a couple styles) and battery are all you need. Don't really need a car to test an ESC to see if it works....
Later EddieO
EddieO is offline
