MuchMore CTX-D Discharger
#752
Originally Posted by James
damn, when i was browsing the 'elec onroad' forum and saw a post in this thread from nexus racing, i was sorta hoping it would be 'we have the CTX-D computer link cable kit in stock'..
hah. I'll keep dreaming.
#755
Just curious for you CtxD users.. Anyone out there use the spintec ICC and this unit... Seems like Ive got a backwards combo.. because the poliarty differences between the 2 units is causing me greif.. when I orient the cells so they fit in the spintec ICC they are then oriented backwards for use in the CTX-d v2.. basically my battery bar tabs would need to face downwards.. has anyone gotten around this..?? I was thinking of doing a little grinding on the top plate so that the bars would slide down inside the unit... In looking at the MM unit as long as I ke my tab legnth short it should not interfere with anything.. Just curious what others are doing as Im sure Im not the only one who has both of these products..
#758
DODGEGUY.. YES Ive updated it to 1.6.. seems to work a little better than 1.5B... Ive not had any issues so far>> Crossing fingers..
Nick : Im not using corally connectors...I was trying not to switch .. Im using battery bars... After talking to others I found out I just need to bend the bar over closely and orient it so the battery fits in.. Im going to try that tonight..
#759
Packs will fit upside-down in the D2 perfectly when you cut your end bars and keep them low to the battery. The D1 had a little more space, so this was not neccessary.
Also, you could use MuchMore's "premium series" end bars...they are very low-profile and fit in the CTX-D2 perfectly:
#760
Cool deal.. I guess Ill be ordering some of those.. But your OUT OF STOCK..
#761
hey muchmore guys i need some info like email adress so i can send in my ctx-d to get it upgraded in canada thanks.
#762
#763
i was using my friend's ctx-d recently - my routine was after a run, pulse discharge to 0.9v per cell, sometimes i'd linear discharge after that.
when reviewing the pulse discharge data, i notice that it does not give average voltage info... does anyone know if the v2 does?
i run 19t, not mod so the run time is not as important to me as voltage...
#764
Originally Posted by A. Rhodes
James handles all of North America - [email protected]
#765
