Help with Spektrum SRS4210 - How to disable AVC?
Hello can anyone help me with disabling AVC? I have read and re-read the Spektrum disabling instructions... simple as they are... it says to insert a second bind plug into the disable location on the RX prior to binding... so I did that and it is still active...
Help is much appreciated.
Video or photograph instructions are even more appreciated - I am a slow learner
Figured it out. Well I didn't exactly - but a good pal did - all it takes is to re-bind the RX / TX with the bind plug and an extra plug in the disable spot on the RX. Leave the Disable Plug in the RX upon completion and remove the bind plug.
Out of curiosity why not disable it from the radio? My DX4S has a field for "inhibit" that disables it. Doesn't it operate as a normal 4 channel when not used with an AVC compatible radio?
quick question does anyone have any problems with their spektrum dx4 on the track? the reason I'm asking is I am about to purchase one but I want to make sure the DSMR module will function. I heard that some drivers had issues with their spektrums.
I haven't used it around tons of other radios but it works pretty well with 2.4ghz wifi nearby and 2-3 other radios. The range test was just a little(100ft) shy of the Futaba, and much farther than my Associated radios.
You're not going to have a problem on the track. I haven't had a single 2.4 glitch on me.
I have the DX3R Pro and I can adjust the servo speed via the scroll down menu in the TX. Does the DX4R DSMR radio have the same feature? I've looked at all the literature the new DSMR radio and it's all about how great the AVC is, which BTW as I read the ROAR rule book is illegal at ROAR races. Also will the DX4R DMSR radio work without AVC, on the older Spectrum receivers that are compatible with my DX3R Pro?
If anyone else around you is using a FlySky or similar radio theres a good chance that it could interfere.
Yes I can confirm my DX4s has a servo speed adjustment. I tried playing with it and it didn't seem to have any effect. Whats it do?
2nd answer, Manual states DX4 is backwards compatible with all DSM and DSMR receivers. Also it looks like Spektrum forsaw ROAR banning it's use because they have included a disable jumper feature. Out of AVC mode it functions as a normal 4 channel with telemetry.
The rule against gyros and other driver aids has been in place with Roar and Ifmar for some time I believe. If I remember correctly it goes back to the early-mid '90s when Schumacher brought a traction control setup to a Worlds. Not disabling it, having it capable of being turned on from the radio, would likely not be considered acceptable.
From the Roar rules:
5.2.3
The use of traction control sensing devices, active suspension devices, and
steering control devices aided by gyroscopes or accelerometers (G-force
sensors) of any kind is strictly prohibited. Sensors may be used for the purpose of passive data recording but not for adjusting the performance of the vehicle while in motion.
Not a Spektrum fan. Sorry, I couldn't resist.
I know this is a bolt-from-the-blue followup but for some reason the Inh option on my DX4S doesn't actually turn off the AVC (and I don't want to have to keep rebinding to turn of AVE). Anyone else having similar issues? Anyone fixed it?
I have just installed a DX4C in my E-Revo and after having to add a servo splitter and rebinding several times, I have the AVC working but I am unable to turn it off from the Radio. I thought the "inh" in the AVC mode was supposed to turn it off but it still seems active. I am going to try to use the second bind plug to disable but I really thought I could use it on the fly and not have to rebind every time I want to have it.
