Animus 18SC Steering Trim Problem? >
Old 05-02-2014 | 07:05 AM
Bryan18sc's Avatar
Default Animus 18SC Steering Trim Problem?
Hello Everyone. I have some trouble with my Steering Trim maintaining setting on truck hoping some can provide some suggestions or advice on how to fix it.
Situation: I recently had to replace the ESC/Servo on car and after rebinding OEM radio controller every time I adjust steering trim and begin to run it. the steering on the car periodically goes out of adjustment turning the front wheels either left or right and then back to center alignment. I have to keep making trim adjustments continuously while driving to keep it in a straight line. I wonder if my Radio Controller is bad that it is not keeping a continuous frequency connection to ESC/servo? Radio Controller has brand new batteries, so I know it not the batteries. The throttle is good with constant response with no glitches or delays. Any help would be greatly appreciated!
Bryan18sc is offline
Old 05-04-2014 | 05:11 PM
fq06's Avatar
Maybe your servo doesn't have the power to center the steering?
Try disconnect the steering link or servo saver or whatever and check for binding in the steering. Without having the servo connected you can tell if its hanging up anywhere.
Move the suspension while checking also.
fq06 is offline
