-   -   Need battries & charger (https://www.rctech.net/forum/radio-electronics/810494-need-battries-charger.html)
ashagab 04-30-2014 10:14 AM
Hi
I'm new here and i wana to buy a hpi sprint 2 flux
but the problem is i just have a 440$
the car is cost 300$
now i just have 140$
can anyone help me to get 2 battries 7.4V 5000mah with charger = 140$:mad:
RoyOne 04-30-2014 10:25 AM
I found these batteries: http://www.smc-racing.net/index.php?...product_id=209
When you find a charger make sure it has a power supply. I am also looking for a charger combo.
ashagab 04-30-2014 10:52 AM
thanks RoyOne but it has good quality also it's 50c good for car ?
rkcann 04-30-2014 11:59 AM
I purchased the Tenergy TB6B charger and have been very happy with its performance. I purchased mine from Amazon and it arrived in less than a week.
As far as batteries, I bought 2 Turnigy nano-tech 5300mah 2S2P 30~60C Hardcase Lipo Packs from Hobbyking. They had very quick shipping from the US warehouse, I had them in about 4 days.
I have only been using them for about 10 cycles, but they have performed very well for me.
Whatever you end up with, just make sure you research to ensure you are getting what is best for you. Good luck.
Hoese37 04-30-2014 04:50 PM
http://www.hobbypartz.com/thac6smbachw.html
Yosh70 04-30-2014 07:16 PM
Get 2 or even 3 of these....http://www.hobbyking.com/hobbyking/s...Lipo_Pack.html
And this charger....http://www.hobbyking.com/hobbyking/s..._GENUINE_.html
With 3 of the lipos, its just over $120 plus shipping.
Yosh70 04-30-2014 07:19 PM
Only problem with that is there's 2 shipping charges.
TLR Chipmunk 04-30-2014 07:47 PM
Can't go wrong with these but if you are worried about two shipping charges get these batteries on the same site as the charger they are good batteries.
http://www.hobbypartz.com/98p-50c-50...22-direct.html
TLR Chipmunk 04-30-2014 07:49 PM
Not criticizing your reply but wouldn't a hard case lipo be better for a car.
ashagab 05-01-2014 12:53 AM
thanks All
now i found 2 kind of charger
1-
IMAX_B6_AC_Charger_Discharger_1_6_Cells_GENUINE =40$
can i use it to charge Duratrax Onyx LiPo or venom LiPo ?
2-
Duratrax Li-24 2S-4S AC Balance Charger Deans =25$
also the battries i found
1-
Duratrax Onyx LiPo 2S 7.4V 5000mAh 25C Hard Case TRA =48$
2-
Venom LiPo 2S 7.4V 5000mAh 30C Hard Case Universal =53$
both from towerHobbies.
it has a good qualit .
wich you think more better of the 2 charger and 2 battries ?
TLR Chipmunk 05-01-2014 06:21 AM
would just get the imax charger the duratrax charger is not going to balance the lipos very well. You need to have a good charger for lipos that is one of the most important things. Lipos will ruin your day if you have a bad charger that causes your car to go up in smoke. But the duratrax lipo is good. I would stay away from venom lipos everyone i have owned has fried within a week or two.
burnineyes 05-01-2014 07:10 PM
I second the Imax charger. The Duratrax will charge your packs just fine, but it will be considerably slower and you will be limited to lipo charging only. The Imax will charge almost any battery you will ever need for RC and other uses.
As for the lipos, I would highly recommend Turnigy Nano-tech or Sky lipos for the best value. The Duratrax lipo is just fine and would get the job done, but you will be paying nearly twice as much for a lesser quality pack. You would be much better off spending the difference on a higher "C" rated pack as it will simply last longer and it could ultimately handle more load if you decide to push the limits of what your car will do. In my opinion the 25C rated generation of lipos was one of the worst. Most of my older 20C packs outperformed and outlasted the 25C packs I owned.
ashagab 05-02-2014 06:25 AM
Now I will buy Imax charger :)
burnineyes
I don't found Turnigy Nano-tech 5000 mah 2s with hard case
TLR Chipmunk 05-02-2014 07:13 AM
Here is the Turnigy 2s 5000mah hardcase
http://www.hobbyking.com/hobbyking/s...case_Pack.html
ashagab 05-02-2014 09:11 AM
is the Constant Discharge: (C) 60C better than low C ? why ?
