Does leaving batteries peaked really harm them?
I've read that but I have always charged mine after using so they are ready for the next time. I tried leaving them at about 50% for storage but I have limited opportunity for drive time and very handy to have the batteries precharged. I found that I wouldn't even bother with it if they were not charged due to time shortages.
I always for years have pre-charged packs the night prior to racing with no ill effect on cycles or the pack.
Now some crazy 17.5t racers will want to do different things right before a race to get the packs to ideal temps with maximum voltage but that is another game all together.
Leaving them fully charged is not ideal, puffing will be the result and they will be ruined. Is it that you have to wait hours for all your lipos to charge? Do you have a good charger, something that can charge your lipo's over 1C?
Like 8ight-E does, I charge mine up the night before. If in a rush, I'll do a 2 or 3C charge and in 1-2 hours, I'll have my batteries ready to go.
What is "next time"? Next day, a week, 2 weeks or longer?
I've left 3 batteries peaked at 8.4v and all 3 puffed. Even 1 day fully charged puffed em.
Now I make sure to always discharge down to 3.7 when the night is over. I invested in a decent charger so I could charge quickly and also discharge.
Charging just before use is better for the lipo, helps keep IR down for good punch and slows the capacity loss. I charged ahead of time, sometimes the night before but frequently before leaving for the track, for years too but once I switched to charging just in time the IR stays low and capacity holds up much better and for far longer.
Besides high powered charging to reduce charge time there are a couple possibilities to consider. Use a storage voltage on the high side of the various recommendations, around 3.85V/cell. Then either use a fast charge mode or manually stop the first charge as the amps tail off to a slow charge. I've even went out for a few warm up laps without charging past storage, with another pack on charge (easier with some classes/uses than others of course).
