Is my new Traxxas Rustler VXL supposed to do this sound? (includes video)
Hi!
I've just bought a new traxxas rustler vxl. Only driven it for about 2-3 packs. Don't know if it made this sound from the beginning, or even if it did, it it's supposed to sound like this. Notice when the engine almost stops, at low rpm:s , it does some high pitched noises that in my ears, doesn't sound very good. Then again, i'm totally new with brushless motors. Thanks!
Video: watch?v=m7bRwNM8PwE
go to youtube, then past this above after the slash (/).
thats normal traxxas tranny sounds
you can quiet it some by adding more greese to the tranny, but it wont shut it up completely
You should see a 4 pole motor and a steel Spur on steel pinion... Passing by... sounds like a F1 1:1 car!
Anyway, ad some lube to whatever gear/dogbones/cvd's you see.... dry lube is good cause it will not attract dirt as the normal ones. It's is generally found in the bikes section.... serious byciclists only use dry lube! :P
There is Rc version of it.. but it's the same thing with RC written on it!
Normal gear noise. You might check the mesh of the pinion and spur, sounds a tad loose, but nothing to worry about.
