lipo charging for storage question >
Old 04-09-2014 | 12:04 AM
Default lipo charging for storage question
Hey guys if I have 2 lipos the same brand and capacity 4s 5800. If charge them both from storage on the same charger and one takes 3000mah and other takes 3800mah which one is better? Many thanks for ur replies in advance.
gnatsum69 is offline
Old 04-09-2014 | 04:08 AM
I'd vote for the 3800mAh being in better condition, if they both started at the same voltage.
Dave H is offline
Old 04-09-2014 | 05:39 AM
dan_vector's Avatar
Do they both hold 4.2v per cell ok at full charge? The 3800 charge will probably have slightly longer runtime but packs discharge at different rates. It may simply be the the 3800 charge pack can maintain voltage for longer than the 3000 but runtimes may be very similar.
dan_vector is offline
Old 04-09-2014 | 04:38 PM
Yeah they both started at the same voltage.
Old 04-09-2014 | 04:40 PM
[QUOTE=dan_vector;13170290]Do they both hold 4.2v per cell ok at full charge? QUOTE]
hey there they both get to 4.2v on all cells but not sure if you are asking if they hold that voltage if I leave them sit? there are intellect/ip 5400mah 35c hardcase packs am running a cycle on them now.
