Transmission help
I have a truck I pull backwards and the transmisson turns but not forward do I need a new transmission?
I'm assuming you mean when you push it forwards the gears don't move? If that's what you mean, that's normal as that's the one-way bearing on the spur gear.
what radio, motor, speed control?
may have the speed control set to forward only, and motor wires reversed |
| All times are GMT -7. It is currently 11:34 AM. |
