Quick question on ESC >
Old 03-05-2014 | 08:12 PM
Default Quick question on ESC
What is the difference between boost and turbo timing? my esc offers both and im trying to figure out which one is best for my use. i have boost set at zero and turbo timing at 10*. We run 2wd mod buggy and SCT.
CaseyD is offline
Old 03-06-2014 | 05:14 AM
lbenton's Avatar
They are the same in that they both up the timing to get more RPM out of the motor..
Except that Turbo will only kick in after a measure of time on full throttle.. meant to give an extra kick of speed on long straights. I think a common delay is like a half second of buried throttle.
Turbo is a very bad idea on a hot motor... with it a full pull on the trigger can cause you to break traction and fishtail when you are planning to go straight and fast. I use it on my 17.5 buggy, but not my 8.5.
lbenton is offline
Old 03-06-2014 | 07:18 AM
Cool thanks.
CaseyD is offline
Old 03-06-2014 | 08:02 AM
Hoese37's Avatar
Boost is ESC timing throughout the entire RPM band, Turbo kicks in at a set RPM.
Hoese37 is offline
