Servo/Steering issues >
Old 03-02-2014 | 04:23 PM
kiwiazbro's Avatar
Default Servo/Steering issues
I got a nice hard whack while racing the other day which put my steering out of whack veering the left of which the trim couldn't correct. I had to disconnect the servo, re-centre, adjust my trim and connect to servo to fix.
However since then it seems any small impact results in this happening again.
Very frustrating since i have to fix mid race meaning I come last.
I'm just a novice so not sure what to look at to fix.
kiwiazbro is offline
Old 03-02-2014 | 04:28 PM
BMenard17's Avatar
There is a motor inside your servo with a pinion pressed on the shaft... I bet that has broke loose and is causing this. Send it in or get a new servo.
BMenard17 is offline
Old 03-02-2014 | 05:48 PM
Bigwave's Avatar
Check the servo horn as well, might have messed up teeth.
Bigwave is offline
Old 03-05-2014 | 04:44 PM
kiwiazbro's Avatar
Thanks for the help. I'll check it out. Are some servos better than others at taking an impact in crashes so to avoid this happening a lot?
Old 03-05-2014 | 05:50 PM
Yosh70's Avatar
You can definitely do better with a digital metal gear servo....I guess that depends on what servo you're running now. A servo saver sounds like something you should run as well, check with the other racers and see what they're running.
Yosh70 is offline
Old 03-05-2014 | 06:01 PM
VenturaDC's Avatar
Sounds like the servo arm, even if it feels like it goes on decently it can have the teeth jacked up and slipping, id just try a new one, just make sure its the correct tooth count for your servo.
VenturaDC is offline
Old 03-05-2014 | 07:32 PM
kiwiazbro's Avatar
Thank you for the help. Much appreciated.
