Alien 120A 2-8S Car ESC BEC Twin
well this have to be one of the most insane powerful and wicked brushless esc I have seen.apparently its for a car and boat I believe that it was made in europe.It look huge but according to the specs this thing can control two motor at the same time.It also can program the motors seperate because it has two brains.it can handle 4 to 12 pole motors up to 8s lipo as well the only thing that i find wired is its only at 120a.It has 10 capacitors, 35v, 270mf, 5.5mm connectors direct soldered on the PCB, battery spark suppression wire, Heat sink, powerful Mosfet, USB link to program it.Has anyone seen one of these before they cost 99 euros.This will be perfect for a 1 5th scale dual 2000kv motor setup.Here is the link they have even more powerful setup that are just plan sick and wicked,here is the link
http://alienpowersystem.com/shop/car...-esc-bec-twin/
Specs:
Size: 90 x 70 x 20 – Weight: 220g
Battery voltage from 2S to 8S.
5V 3A BEC.
Simply set function value by Pro-Box, by PC via USB kits or by trasmitter.
Two way communication while connecting it with computer.
Firmware will be upgraded automatically.
LVC
Timing settings may be adjusted (0°- 30°)per degree to suit the motor type
3 types of throttle curve
3 types of acceleration control.
Motor rotation programmable.
Auto cut off power within 3 seconds in case of signal loss.
Function Value:
BATTERY TYPE:Ni-XX、Li-XX
NUMBER OF CELLS: Auto,2,3…
LVC: programmable
PWM frequency: 8 – 16 – 32
FORWARD POINT:Auto、fixed 1.0mS、fixed 1.1mS、fixed 1.2mS、fixed 1.3mS、fixed 1.4mS, fixed 1.5mS
REVERSE POINT:Auto、fixed 1.7mS、fixed 1.8mS、fixed 1.9mS、fixed 2.0mS
MOTOR POLE N°:motor poles number, 2-4, 6-10, 12-14 (HELI ONLY)
THROTTLE CURVER: Logarithmical、linear、Exponential
ACCELERATION: Soft / Medium / Hard
TIMING MONITOR:On/Off
DELAY TIME FORWARD TO REVERSE: MS (CAR/BOAT ONLY)
PWM LIMIT: 0N/OFF (CAR/BOAT)
MODE HELI: CONSTANT RPM/NORMAL (GOVERNOR MODE)
CURRENT LIMIT: AMP (CAR ONLY)
ABS BRAKING: % (CAR ONLY)
MOTOR TIMING DEGREES: 0°、1°、2°、3°、4°……30°
ROTATION:Left/Right
REVERSE: ON/OFF (CAR/BOAT ONLY)
Specs:
5V 3A BEC.
LVC
Function Value:
LVC: programmable
ROTATION:Left/Right
