Speed passion led programming box question >
Old 02-12-2014 | 03:41 PM
chad_h's Avatar
Default Speed passion led programming box question
Why does my led program box have an unidentified setting? After #6 drag brake with 9 values, #7 is neutral range according to the manual. However It has 9 values also and it's only supposed to have 6. #8 has 6 for the neutral rangeI need to update it but can't because no wifi or laptop. I really think this should work out of the box without update.I'm referring to page 13 in reventon R manual for info.Esc is SP REVENTON R
chad_h is offline
Old 02-13-2014 | 06:35 AM
liljohn1064's Avatar
For those reading this, it is a missing item in the table on P.13.
#7 is actually Reverse Force Percentage. Max it out and set this on your transmitter instead. It affects braking force as well for Forward with Brakes only setting (race).
#8 is Neutral Range.
#9 is Overheat Protection
Bench check items:
#10 is ESC Temp
#11 is Battery Voltage
#12 is ESC Firmware - current
liljohn1064 is offline
