ESC green light off when servo connected?
This issue is for a Kyosho Lazer 5 RTR that was running.
If I connect the ESC to channel 2, and the servo to channel 1, the light on the ESC never comes on when I power up the transmitter and car, and nothing works.
If I connect the ESC to channel 2, and the servo not connected, the light on the ESC is green and the throttle/power works.
I bought a spare reciever and servo that I've tried, and get the same result. I'm assuming this isn't some type of configuration issues. So the only two things left as possible issues ar ethe ESC or the transmitter. Is there a way to tell why I get no response with the servo connected?
Servo: Savox 1258G
ESC: Perfex KA-15L
Transmitter\Reciever: Perfex KT-6\KR-6
Bettery: Orion 3300 NiMH
Thx.
Servo: Savox 1258G
ESC: Perfex KA-15L
Thx.
I had the same issue with my sons kyosho rtr sct, for me it was the servo that shorted the receiver that in turn took out the esc. Ended up just upgrading everything and have never had an issue again. I've learned over the years the rtr electronics are pretty much worthless
Thanks for the reply VentureDC. Something in the servo was my first guess. That's why I bought a second servo, but had same results. Then I tried a new reciever, same result. Not sure if it could be the ESC or transmitter. It work's when the servo is not connected. Just seems weird!?
The second servo was the same type, a Savox 1258. Would it be worth trying a different ESC? If yes, what would be compatable with my components below, that would provide more power?
Thanks.
Servo: Savox 1258G
ESC: Perfex KA-15L
Thanks.
Servo: Savox 1258G
ESC: Perfex KA-15L
So I searched 'capacitor' on amainhobbies. Reading the Novak Glitch Buster, it states it you simply connect it to an open channel on the reciever. I have one open BATT channel. Is it really that simple to install? Is this Novak Glitch Buster a good one? $10.99 seems like a worth while thing to rty.
Spektrum Voltage Protector
Glitch Buster Capacitor
But, since your's won't even work to begin with, don't expect it to help, for your situation, which is apparently more severe than what most are experienced with. You appear to need a lot more power, not just some short term help that a cap offers.
Dave H,
So you think I need more power. I didn't follow your comment "If you have a receiver battery that could be used for trouble shooting, see if a different power source can make the servo work". Is the BATT channel something I can connect another power source to? If yes, is having two power sources something typical, or just for trouble shooting? Sorry for all the dumb questions. Thx again.
Dave H,
Course you can just leave the ESC disconnected, start with just seeing if you can get the servo going.
