-   -   Battery issue.maybe? (https://www.rctech.net/forum/radio-electronics/788353-battery-issue-maybe.html)
malcnz 01-25-2014 08:17 PM
Have just put a 2700 IP receiver lipo pack on my rock crawler to use with the Tekin FXR system and if put under some pressure like climbing up something with resistance it just turns its self off and if i unplug and reblug it is fine again till resistance again and didnt happen with the Hyperion 1300mah powerpack i had on there so could it be the fact it is a receiver pack and not up to the job?
Thanks.
dan_vector 01-25-2014 11:14 PM
Do you still have the old pack? Try it to see if the problem goes away. If it does then I guess that answers the question. Although the receiver pack shouldn't affect the driving power of the ESC. First step try the old pack and then we can think of the next step in sourcing the problem.
malcnz 01-26-2014 01:32 AM
yeah have tryed old pack and it was fine so guess its the battery and maybe the receiver pack draw isnt up to it once you give it some welly.
dan_vector 01-26-2014 06:03 AM
Perhaps. Seems strange though! Is the new pack a particularly low C rating compared to the old pack?
huzzler 01-26-2014 09:37 AM
So are you using the receiver pack to run your motor also? I don't think a receiver pack is going to have enough c rating to push a motor. They are meant to just run servos. The pack you are talking about only has a 5c rating. The Hyperion is also a 3s pack 11.1 volt compared to the 7.4 Ip pack and the Hyperion is 25c.
malcnz 01-26-2014 01:12 PM
yeah receiver only 5c so guess not enough to run motor..well it does but if you push it it shuts down.the Hyperion is only 2 cell as well but yeah 25c so will just carry on with that..was trying to get some extra run time from the 2700 and there doesnt seem to be a lot of batteries around hump pack size that may work as all seem to be receiver packs with lower c rating....lucky i have a JQ white edition coming so will use the receiver pack for that. cheers.
dan_vector 01-27-2014 01:50 AM
Aha! It wasn't clear from your OP that you were running the motor from the Rx pack! Of course that would be the reason behind the problem. Oh well Im glad you got it sorted and the new pack will be useful for the JQ buggy - enjoy!
malcnz 01-27-2014 02:34 AM
yeah cheers..it almost worked as went along ok till i climbed something and put it under load i guess..bugger :)
dan_vector 01-27-2014 04:27 AM
Yeah and that's kind of important for a rock crawler :lol:
