-   -   Alternative to control 2 servos with same channel (https://www.rctech.net/forum/radio-electronics/785574-alternative-control-2-servos-same-channel.html)
mako21 01-14-2014 07:32 AM
1 Attachment(s)
Happy 2014 to all! With the new year a a new RC truck I gave my son for Christmas (an SCX10 Rubicon), I started with the task of upgrading this new toy (We already had a Traxxas Slash and the upgrade/fixing never ends). What I'm basically adding is a Bulldog winch (from RC4WD) but I did not ordered the wireless controller as a kit and later learned that I will need a radio with a third channel with a 3 position switch. The radio that came with the Axial is a basic 2 channel system but looking at various alternatives on the internet I will like to try the idea of using the steering channel to control the winch by using a switch that may allow me to alternate which servo (steering or winch) the steering wheel of the TX will control. The problem is I need to understand what the 3 wires are and what switch to use. Will I need a 6 pole switch or any DPDT switch? If so, this will only allow me to switch 2 of the 3 wires, is there a common wire than may be bundle together between the servo, RX and winch? I was thinking o using a Y cable (with 2 female ends and one male and buy a switch to make the connection myself but was wondering if this harness can be available already (looked at RC Planet and Tower Hobbies but have not found anything similar).
mkiiina 01-14-2014 07:42 AM
I wouldn't recommend what you are doing. Usually when you trying to control 2 items from the same channel its not something you always need to use (such as steering). If you had a 3 channel you could have throttle, steering, and then split the 3rd to do lights/winch (usually its setup on a 6 step system like you guessed already).
Check out the GT3C from hobbypartz as a cheap upgrade (~$50)
mako21 01-14-2014 08:02 AM
Thanks for the reply! Will take a look into this option today. I agree 100% with you that this is the best option, is just that I was already into other upgrades that this Rubicon needs (like aluminum suspension and steering links, hub carriers and other accessories that I ordered already or I'm looking at) and was looking a a quick/cheap alternative while I get the chance to have a more permanent and better solution. But will look at this system you recommend today maybe I just spend the extra $$ and just solve the issue. Question, is the 3rd channel in this radio a reversing or 3 position switch or will I have to make any modification? I'm asking because I already have a Traxxas TQi (4 channels I use in my Traxxas Slash VXL) and was thinking on buying just the receiver to control my slash as well as the SCX10 with the same controller but read that I will have to change one of the switch in the TX because is just an on/off or a 2 position switch and the winch will need a 3 position on/off/on-reverse? function.
