ESC Throttle Issue
Old 01-11-2014 | 03:36 PM
Default ESC Throttle Issue
I have a Novak Pulse with the M12 SSR that I am trying use with a Spektrum DX3R Pro transmitter. I can not get the throttle to work. I have tried different receivers with same results.
I have verified that the ESC is in standard mode not the enhanced mode for the M12. I performed the one step setup. I did a data reset. Always the same results, I get the red light, blinking white...red is status, white is blinky. Pull trigger get solid green indicating throttle applied, red goes out, if I push trigger forward green blinks indicating reverse throttle applied. I did the hall sensor test that the ESC provides, it passed.
If I run the throttle trim on the transmitter up to 100% the motor runs and I can apply a slight amount of throttle.
Any thoughts on what is going on or how to fix it? I did send Novak an email today but was hoping one of the rctech experts would have an answer.
Thanks,
Bill
uscgretired is offline
Old 01-11-2014 | 04:40 PM
ThePanda's Avatar
It sounds like you set your end points incorrectly, that's why you can only do it when you turn throttle trim up. It I remember correctly when selling up it is hold the button, turn on. Light should change, pull to full throttle, light should change, push to full reverse, light change, let return to neutral trigger, lights should do their flash dance thing, and points are set.
ThePanda is offline
Old 01-11-2014 | 05:04 PM
Those are basically the instructions given in the one touch programming instructions that I have tried multiple times....I agree with your logic on the end points just can't figure out another way to set them that works.
Old 01-11-2014 | 05:42 PM
VenturaDC's Avatar
Its been my understanding that not all motors are compatable with all Novak esc's, due to not having a temp sensor output on the motor (or something like that) This could be the case here, do you have another motor just for testing purposes?
VenturaDC is offline
Old 01-11-2014 | 06:10 PM
ThePanda's Avatar
Is something set screwy on your radio?
ThePanda is offline
Old 01-11-2014 | 06:12 PM
Pretty much a wild guess here, but sometimes the throttle channel on the radio needs to be reversed. Easy enough to try. Or perhaps try a different clean model memory on the radio?
Dave H is offline
Old 01-11-2014 | 06:25 PM
VenturaDC's Avatar
Just remember to re do the one touch programming for the throttle points again after reversing the throttle servo direction on the radio
Old 01-11-2014 | 07:36 PM
racer1812's Avatar
Super Moderator
The original Havoc was the only esc that had that issue.
racer1812 is offline
Old 01-11-2014 | 07:57 PM
VenturaDC's Avatar
Gotcha, good to know. Not a Novak guy so was just trying to remember what I had read in the forums about that, thanks!
Old 01-12-2014 | 05:51 PM
I tried both idea...used a different, clean model memory and tried reversing the throttle channel. Reset end points both times. Same results. Thanks for the thought!
Old 01-12-2014 | 06:37 PM
Just for the heck of it I tried another transmitter also...same results.
Old 01-13-2014 | 01:21 PM
Suspended
does that esc have a dead band setting for the throttle? I know my tekin rx8 gen2 and viper both will not work if this setting isn't right.
to me it sounds like you have it bound properly and all but now you need to go through and set up the setting of the esc to function with your radio and motor properly.
none of my cars have ever worked right out of the gate after installing a new esc. I always have had to go through the setting and make it right.
http://teamnovak.com/file_download/1...TrackGuide.pdf
I see your esc has the dead band setting as well as a "minimum drive" setting. which says the following,
" Increasing this setting starts forward drive at a stronger/higher level"
also if that radio has any kind of traction control stuff try turning that stuff off for now.
mtpocketsracing is offline
Old 01-13-2014 | 05:06 PM
I did a data reset which puts the ESC back to factory defaults for throttle profile number 1. Are you thinking I should raise or lower the settings for Dead Band and Minimum Drive? The radio has traction control but it is off, I have never tried the feature.
Thanks,
Bill
Old 01-14-2014 | 11:56 AM
tufferwilde's Avatar
Out of curiosity - how old is the Pulse? Is it the version 1.2? If not, it may not operate correctly utilizing the high speed SSR mode on the M12. If it is the newest version, while in the custom programming mode you will have 19 choices (the trans/receiver rate selection will be the red and green lights)
IF you don't have the newer version, you should be able to change the M12 out of the high speed setup for the next one down and see corrected performance.
Wilde
tufferwilde is offline
Old 01-14-2014 | 02:42 PM
Suspended
Wilde
I was thinking on this route until I realized he's using a spektrum radio. I seen M12 and immediately thought of airtronics.
