Sensorcable broken
Old 01-08-2014 | 11:31 AM
Default Sensorcable broken
Hi. I have recently built my Tamiya XV-01 and are nearly done. I have fitted the electronics and I am about to calibrate my esc and motor. Then disaster struck I think. One of the plugs on the sensorcable have been broken and I am nervous about what`s going to happen if I proceed.
Can I fix this myself, does that tiny cable matter? (there are 6 on the socket) It is the plug at the far end of the socket that has come loose.
frodepv is offline
Old 01-08-2014 | 11:42 AM
MarkA's Avatar
Sensor cables are relatively cheap and failures relatively common. It is however, very important to have a good one on there to ensure proper sensored motor/ESC operation. Some ESC's/motors can also run in a sensorless mode, i.e. with no cable at all but then the motor will cog at low speed and be generally not as smooth as it would if it was sensored.
MarkA is offline
Old 01-08-2014 | 11:55 AM
Gone shopping...
frodepv is offline
Old 01-08-2014 | 11:53 PM
dan_vector's Avatar
Originally Posted by frodepv
Gone shopping...
By all means carry on and setup the esc etc and even have a couple runs if it'll be a few days before you get a new sensor cable. Won't be as smooth but you won't do any damage.
dan_vector is offline
Old 01-09-2014 | 02:42 PM
Thumbs up Time to try out the car
Thanks for the help... This weekend are there going to be some
frodepv is offline
