Help with ESC soldering please!
First off I'm not entirely new to soldering however I'm definitely no pro.
My issue is, I bought a Hobbywing XeRun 150a used and the battery leads are not long enough for me. I snipped the wires and removed my battery connector. I can't get the battery post hot enough to desolder the wire. I feel like the heat is just getting sacked though the heat sink.
I just got for xmas a Hakko FX-888D. I had it set up to 850 degrees. Still nothing. I can't post I video if that will help but for now here's a picture of what I see.
Here is a quick video. Maybe it's my technique? I know the solder was heavy in this one.
https://www.youtube.com/watch?v=R2Qp...e_gdata_player
it looks like your tip oxidized, you will need to get a tip cleaner, or maybe you might be able to polish it off.
try clipping down the wire really short, so less heat gets absorbed and dissipated in the wire.
That is a very dirty and oxidized tip. No, a wire brush will only make it worse.
Get some tip cleaner/tinning from Radio Shack and use it every time you put the iron away. Didn't the 888 come with a cleaner (looks like a brillo pad made of brass)? Use it.
No, that will only worsen the tip.
The 888 comes with a tip cleaner, don't you use it? Looks like http://gokimco.com/brass-coil-insert.htmlis
Go to Radio Shack and get a tin of tip cleaner.
I have a ten year old Hakko 936 with the original tip and it still works like new and is a shiny as new.
