Like Tree15Likes
Tekin Hotwire App!!
Old 01-19-2014 | 05:00 AM
  #271
jsrocket13's Avatar
RS gen2 the lights don't even come on.
jsrocket13 is offline
Old 01-19-2014 | 07:25 AM
  #272
fq06's Avatar
Did you try it with the lipo powering the ESC?
fq06 is offline
Old 01-19-2014 | 08:15 AM
  #273
jsrocket13's Avatar
Not yet I haven't even wired it up yet.
Old 01-19-2014 | 08:16 AM
  #274
fq06's Avatar
Once you get it wired up try that.
fq06 is offline
Old 01-19-2014 | 07:52 PM
  #275
jsrocket13's Avatar
Ok thanks.
Old 01-27-2014 | 08:59 PM
  #276
oldrcr's Avatar
Default does android 4.4 work?
Hi,
has anyone tried Android 4.4 with the Tekin app?
Thanks.
oldrcr is offline
Old 01-28-2014 | 07:50 AM
  #277
Randy_Pike's Avatar
Team Tekin
The app isn't working on any 4.4 device we've tried so far. Issue is in the AOS missing some OTG support structure. Other developers we talk to are also fighting the issue and working with Google to fix the problem.
You can clearly see it being an AOS issue on certain devices. My Samsung Tab2 10.1 for example. App runs great on 4.1.2 , but if I install 4.2.2 it won't work.
It was supposed to be a "Security" update but they've yet to complete the project is what we're told.
Randy_Pike is offline
Old 02-02-2014 | 09:56 AM
  #278
Is there a list of devices that work? Looking cheap tablet for tekin hot wire app.
kahuna2793 is offline
Old 02-02-2014 | 01:47 PM
  #279
What cable do you use with the droid? How far out is support to use the mobile app with the gen 1 RS?
Cautrell05 is offline
Old 02-02-2014 | 02:20 PM
  #280
Hoese37's Avatar
Here http://www.teamtekin.com/forum/viewtopic.php?f=40&t=170
Hoese37 is offline
Old 02-07-2014 | 03:16 PM
  #281
Randy_Pike's Avatar
Team Tekin
Some news to report..... Samsung S4 running 4.3 has a working Hotwire app! More to follow.
Old 02-07-2014 | 03:28 PM
  #282
Carranza76's Avatar
Guess I will try my i-view i bought again to see if it will finally work.
Carranza76 is offline
Old 02-07-2014 | 03:35 PM
  #283
Randy_Pike's Avatar
Team Tekin
We've had it working on Iviews running 4.1 or lower the entire time. This fix that that is being tested should alleviate the AOS version issues we've had on 4.2 or newer.
Old 02-07-2014 | 03:50 PM
  #284
Carranza76's Avatar
My Iview is 4.2, came out of the box that way. Tried to find the software to reverse it back but was unable.
If what you are saying is you found a way to make it work that would be awesome.
My work phone is a HTC EVO and it powers up the ESC and the hotwire but the phone does not recognize it. It is 4.1.1 software.
Sooner or later it will work.
Old 02-07-2014 | 04:11 PM
  #285
jmackani's Avatar
Android 4.4 comes with SE android enforcing if I recall. This could very well block applications from working. Try installing the selinux mode changer app to switch from enforcing to permissive mode on 4.4 devices. See here for more info https://www.xda-developers.com/andro...-selinux-mode/
jmackani is offline
