Help with motor / esc
Recently got back into the hobby with the purchase of a rc12 5.2. I have installed a Trinity D3.5 17.5, Tekin RS Pro Gen 2 esc, and Corally Booster.
The motor spins free when not in contact with the spur, and makes a click when meshed. The gear mesh is good. I have all the wires connected correctly. The sensor wire is installed. And I have the esc set to blinky mode. The motor makes a squealing noise when I pull the trigger slowly or at full position. The noise will go away but comes back when I let off and reapply the throttle. Sometimes when I apply the throttle the motor will make noise and spin back and forth. Let go and reapply and the car will move forward very slowly. I did disassemble the motor before I installed it. I had to shift the mounting holes to line up with the motor mount, and didn't know I could turn the end without disassembly. I wonder if I put it back together correctly? Timing is set to 0. All parts are new out of the box and this is my first attempt to drive the car since assembly. Any suggestions? |
Originally Posted by cdraughon
(Post 12813745)
No. Don't have another motor to try. I can't get the incr button on the EEC to advance the settings. I wonder if the EEC is defective.
Anyone else have some idea of what is happening?
| All times are GMT -7. It is currently 11:48 PM. |
