Water proofing batteries? >
Old 11-10-2013 | 06:47 PM
Default Water proofing batteries?
Does anyone know if there is a way to water proof batteries so I can run my slash in the winter?
prorcguy is offline
Old 11-10-2013 | 06:53 PM
ThePanda's Avatar
run a chassis cover. or put the batteries into a little plastic baggie.
ThePanda is offline
Old 11-11-2013 | 02:10 AM
Plasti-dip
Johnnysplits is offline
Old 11-11-2013 | 04:10 AM
whitrzac's Avatar
Batteries are water proof...
whitrzac is offline
Old 11-11-2013 | 04:25 AM
ThePanda's Avatar
The connectors aren't. Throw a lipo into the bathtub woth water and poof!
ThePanda is offline
Old 11-11-2013 | 05:55 AM
whitrzac's Avatar
Nice try...
FYI: water is not very conductive.
whitrzac is offline
Old 11-11-2013 | 05:59 AM
lbenton's Avatar
What about neverwet?
http://www.rustoleum.com/about-rust-...eum-never-wet/
lbenton is offline
Old 11-11-2013 | 06:26 AM
ThePanda's Avatar
Nice try...
Dang, what was I thinking.
Lithium as an element is reactive with water being a metal to get that reaction though you eould have to expose the lithium to the water by breaking the case, but its going to puff or burn if you pierce the shell anyways.
ThePanda is offline
Old 11-12-2013 | 02:15 AM
Originally Posted by lbenton
Yeah, that would work as well as using plasti-dip. Then i would smear dielectric grease all over the connectors.
Old 11-12-2013 | 03:51 AM
Nice try...
Are all electrics & electronics water proof then? Even if the water is not deionized?
Dave H is offline
Old 11-12-2013 | 05:27 AM
whitrzac's Avatar
Some people thought a firmware upgrade would make their iphones waterproof...
Find me ONE case of a lipo being damaged from water.
whitrzac is offline
Old 11-12-2013 | 05:46 AM
lbenton's Avatar
I wonder about using it on all the plastics of a car. It would cut cleaning down by how much time at the end of the day... almost nothing would stick to it...
lbenton is offline
Old 11-12-2013 | 03:53 PM
After cleaning, I spray this stuff liberally all over...makes cleaning easier...
http://www.amazon.com/CRC-05074-Sili...d_sim_sbs_hi_1
Old 11-20-2013 | 04:05 AM
Water is also corrosive, I've seen packs with enough corrosion on the connections and wiring, along with flexing, to cause failures. Granted not the cell itself which I assume is your point, but still no workie.
Dave H is offline
