-   -   MyLaps Problem (https://www.rctech.net/forum/radio-electronics/764382-mylaps-problem.html)
Andy Koback 10-12-2013 09:22 AM
MyLaps Problem
Anyone ever have a problem with a My Laps transponder that quit working?
Odin544 10-12-2013 09:38 AM
How are the wires? And which version is it?
Grasschopper 10-12-2013 09:49 AM
I was getting inconsistent recording my last weekend out in one of my cars and it turns out that the pins were not making good contact with the RX. I took them out of the connecter and pushed it in a bit so that it made better contact. My wires are in good shape so I think I'm all good now but we will see.
Check how tight the plug is into the RX.
Odin544 10-12-2013 10:07 AM
Very good suggestion. I've had the same thing happen with just about all of mine too. Use a needle or exact knife to tighten them up.
Andy Koback 10-12-2013 11:56 AM
This is the 2 wire Hybrid, "White Edition". Tested the wires with a fluke and read good. Also removed the plug and connected the 2 wires directly into rec. and still nothing. Tried a different transponder and works fine so that rules out the receiver. Has to be something internal. Sent a message to My Laps but haven't gotten a response yet. Just wondering what the repair cost will be. Never heard of anyone having this kind of issue.
Odin544 10-12-2013 03:37 PM
Pretty sure Mylaps does not do any repairs. They just sell you a new one. I've opened up the previous version of transponders to replace wires and such but not the newer hybrid or RC4. So I don't know how difficult it would be to do it yourself. They are epoxy filled though so it's quite a headache to get to the board itself.
You double checked that it was plugged into the RX correctly I assume? Weird as I've never seen a Mylaps personal transponder go bad. It's always been bad wires in my experience. It's bound to happen I suppose.
Andy Koback 10-12-2013 03:57 PM
Yea I tried the wires both ways with no results. I suppose there's no easy way to get the epoxy out either, huh? Will wait and see what My Laps says in response. If they won't fix it, I'll try and get it apart just to see what happened.
Odin544 10-13-2013 02:31 AM
The epoxy melts and flakes away with heat. I used a soldering iron to get the majority off. You obviously have to be careful not to damage the board. No real easy way that I know of.
It does smell horrible and makes quite a mess.
Andy Koback 10-13-2013 08:58 AM
Gotcha!
Flygio 10-13-2013 10:17 AM
Do you know any chemical that would do the job instead of heat?
Odin544 10-14-2013 01:37 AM
I dont know of any that would be safe to use. If you could find something to dissolve the epoxy the question becomes, What would it do to the board and components?
vlad_vy 10-15-2013 03:08 AM
4 Attachment(s)
Internals of Mylaps RC4 Hybrid transponder
Andy Koback 10-15-2013 09:56 AM
Now...how did you get it apart without doing any damage to the internals?
swarf 12-14-2013 03:02 PM
I tried soldering a fan in a "Y" to my transponder last night. When I plugged the whole thing in to the rx it didn't work anymore. I didn't hold the iron on for longer than 6 sec and it wasn't very hot to begin with. Are these overly sensitive to heat? I really can't afford this...
