Sanwa Super Vortex Zero ESC
#76
re: boost setting, i cannot explain it well but Code 1 and Code 3 (Aux2) sets the boost, while Code 2 is turbo. i just did a trial and error, good thing there's SSL so i don't have to pit to change settings.
re: Throttle feel, i think 0 setting is comparable to 100% punch in other ESCs, and the more throttle feel you dial in, the less punch you have on the Vortex that's why it feels smoother.
#77
Thanks Voodoo.
Interesting point about the "Feel" setting. I had not considered that it may be "punch" My car has felt like it lacked Punch and so I will try the other end of the scale and report back before finding the optimum setting for my track.
I have a test session planned for this weekend and so I will report back.
Sadly no ssl for me, currently saving for the mt4s.. and so it could be a long session haha!
Cheers
Cheers
#78
Here's the 2 page radio setting you want to print out to keep in your bag, it has the EXACT numbers on what every setting means.
Example: AUX1: Code 1 = (default 0 = 100%) Aux value adjustment range 0 (100%) to -100 (0%) in 1% increments.
http://www.airtronics.net/media/uplo...sers_Guide.pdf
I also created a label for the bottom of my m12 since I can't rename the AUX values like the m12s & mt4s.
#79
I run the combo esc and the sanwa low volt servo. It works like s charm, perfect!
#83
Seeking some settings advise please.
I run 13.5 Boosted on a small/medium on road track. My previous ESC I was able to enter specific settings. What settings on the Vortex should I be using to replicate this;
Boost 50 degrees
Start 4,000
Finish 16,000
No turbo,
Punch Rate stage 1 20
Punch rate stage 2 20
Punch switch 50%
I have read this thread, the one in the electronics section and the instruction sheet a few times and I am still not sure what some settings do.
Can someone that understands them offer an explanation (not copy the instructions but explain what each does - i.e. boost setting - if I set this to Maximum, how many degrees of boost does it apply..?) - what effect does the throttle feel have - does this provide a more sensitive throttle application - if so, in what scenario would you use anything less than the best "feel"
Cheers,
Boost 50 degrees
Start 4,000
Finish 16,000
No turbo,
Punch switch 50%
Cheers,
#85
yeah i used a y connector for my vortex plus. its only downside if you ask me.
#87
as some ppl dont use AMB you can just connect directly with Fan instead
#88
Anyone have trouble adjusting the manual 1-4 settings? I cannot seem to set these.
1. I make sure both transmitter and ESC are on.
2. I hold down the white program button (the one on the power switch) for about 4 or 5 seconds and the ESC setting lights flash.
There is a blue and white lite that flash consistently, but I cannot see that they flash any certain amount of times.
3. I try clicking the white setup button to see if I am in program mode, but the lights just consistently flash.
A bit lost. I looked online for videos and couldn't find anything in English.
Can anyone help? Or post a video? Or just walk me through it a bit better than the manual?
Thanks.
Other notes: Jumper is set to SSL on and I am getting telemetery. I am using this with a MT4-S.
Thanks.
#90
Thanks.
Thanks.
