-   -   New hobbywing combo problem (https://www.rctech.net/forum/radio-electronics/757107-new-hobbywing-combo-problem.html)
brandon32689 09-08-2013 10:17 AM
Got a brand new 1800kv hobbywing 150amp combo.
Put it in my losi 2.0 truggy and noticed it shuttered real weird just going up and down the street. I re calibrated esc and re blinded receiver.
I'm using a dx4s remote and the new receivers they come with. I did have a mm 2200 in this truck before and was running great.
Also I ordered new hitec 7955tg servo and threw a new glitch buster in. At the track the truggy would run good for a second then start shaking Or take off on its own, I tried diff glitch buster, different batteries and different receiver still did same crap but it will run fine for a min or 2 then start acting up. Using 4 cells 5000 40c
I noticed when it shutters the motor wires jump and shake. I am not going to dig into it so boxed it back up and emailed hobby partz, does anyone know how well the customer service is? I am hoping I just got a dud and new one will get here and work great
EricW 09-08-2013 10:30 AM
Did you try a new sensor wire?
brandon32689 09-08-2013 10:33 AM
No it's my first sensored motor, but I did try it with no sensor wire at all and same thing, also my buddie did a ohm test on the wire and told me it was good
timannnn6 09-08-2013 11:18 AM
You should post in the HW support forum. Probably get more support there.
http://www.rctech.net/forum/electric...l#post12526288
latemodel13 09-08-2013 12:42 PM
Test
If you have another motor to use I would hook it up and try it. It sounds to me like a phase is not working on the motor.
brandon32689 09-08-2013 12:46 PM
I don't have another motor with the small bullet connectors and don't want to start cutting and soldering on this esc or anything so I'm hoping I can exchange it all for new. I did put my own plug on the esc but solder job came out nice I solder all the time that's not it
theblitzkidd 09-08-2013 01:02 PM
Sounds like something is cooked on the board, I had a castle esc do the same thing!
brandon32689 09-08-2013 06:23 PM
Yeah idk I just hope they take care of me always nervous dealing with a new company. Everyone else in this hobby has been great to deal with so far
