ICHARGER 308 Duo
#227
What are you guys seeing for "resting" voltage after a charge on a 2S LiPo? Charge cycle finishes, you press stop and look at the voltage reading at the bottom of the display for that channel. This is the first charger I've had that has this type of display so I've never really had this data readily available or even thought about checking it. I'm getting readings of about 8.35V to 8.36V (confirmed with a volt meter). This sound right?
IMO....I personally see no reason to worry about this unless you are running some kind of highly regulated on-road class where every millisecond matters amd battery voltages are being tech'd. In off-road, we are so over-powered, and over-batteried typically....it just doesnt seem to make a difference.
#228
I have a couple questions.
Does the 308duo come with a temp sensor?
Being the first time using a temp sensor is it plug and play or is the some setting up(beside the temp cutoff you want)?
If it doesn't come with one where can i find one and is it brand specific?
#230
You can get them here. Great service,fast shipping
http://www.buddyrc.com/icharger-temperature-sensor.html
#231
One side of my 308D has begun acting up. I have had it about 2 months. It has stopped balancing, either on charge or balance only. I swapped leads to trouble shoot, but it continues to charge forever, without balancing. I tried refreshing the settings and it is still not functioning. I ordered it from www.heli-heli.com and have sent a request into them for information about warranty repair/exchange. Has anyone else had this problem? If so how were you able to get it repaired? I can't seem to find a way to contact jun-si, and I know some retailers want you to deal with the manufacturer when it comes to defective products.
#232
I want to hammer cycle my 2s packs on both ports at the same time on 30 amps. What size supply do I need? My current one will do it with one cells but not two.
#233
#234
I've read some places that you can tweak the settings on the 308 Duo to get a very-close-to 4.2 volts / cell charge. At first I thought it was the "slow balance" mode, but I'm not sure. Is there a way to tell the charger to take a bit longer but to try to get the cells to as close to 4.2 volts as possible?
#235
#238
I also have two 900 watt power supplies which I got for $60 each from a guy on Helifreak, in series I have 1800 watts @ 24 volts
#240
Totally But it's a deal that can't be beat, check it out: http://www.helifreak.com/showthread.php?t=526901
I was getting ready to spend $400 on a 1200 watt power supply when I came across that thread. Those 900 watt units are super quiet, small and work great. Both come with banana plugs and a cable to wire them in series if needed.
