Proper Discharge Amperage for Nimh Batteries
Hey all!
Does the AMPs you discharge at for Nimh batterys matter other than the time it takes to discharge the battery? Does it hurt the battery or battery performance( by making a memory of low output) if you use the low amp discharge ( 1-2A ) on most chargers? Also whats the MAX you should discharge at?
I'm trying to figure out what new charger to get and all the chargers have a very low discharge rate ( 1-2A ). Its sometimes a number of months on some batteries between use so I'd like to be able to cycle them ( discharge and then charge) to keep them in good shape. My local hobby shop employee told me never to use the discharge on the chargers however as it will put memory in the battery that is only has to output power slowly and ruin the performance on the battery. Is this true or BS?
Thanks so much for the help!!!!
Jim
Ps. Also wanted to verify... you never need to discharge or cycle LiPos correct? The discharge would be for NIMH batteries only?
Jim
There is a lot of truth to the discharge rate on NiMH batteries affecting memory. I'm not sure why they put discharge on chargers because it is generally inadequate for storage or cycling. I would use an automotive light bulb array to pull them down if you don't use a vehicle to do so. This will simulate the higher discharge rate like running an RC vehicle fairly hard. Be sure to monitor the voltage when using on LiPos.
LiPos will need to be discharged occasionally, especially if you fully charge them and don't run them or plan to for more than several days. They sit at a 3.7 V storage charge per cell. Their performance is improved by cycling new ones about 10 cycles. I wouldn't do that with a charger, but by running in a vehicle down to 3.5 - 3.7V per cell and then balance charging. Many ESCs will allow you to set the LiPo cutoff voltage yourself. Don't set it too low.
Hey all!
Another good thing about LiPos is that they don't have to be discharged to full depletion to recharge as they don't have memory like the NiMH batts do. I like to run a couple of heats and recharge for the main. Just don't let them get too hot.
I prefer LiFe packs for receivers/transmitters anyway. Lighter and last much longer.
