Mamba Max Pro issue
Old 07-17-2013 | 04:08 PM
Default Mamba Max Pro issue
Looking for some help! I just programmed by MMP with my laptop. I did the torque limit test, calibrated it to my tx, and all. I have it paired with a Tekin Gen2 13.5. ESC is set to smart sense.
Here's my issue: I hook up a battery, turn everything on, and hit the throttle with my Losi SCB on the stand and it's good to go. I then take the buggy off the stand, put it on the floor, and hit the throttle and it goes about two or three feet then stops. I let off the throttle and then engage it again and it does the exact same thing. Pick it back up, put it on the stand, hit the throttle again, and it takes off.
Help!!!
thefasterpastor is offline
Old 07-17-2013 | 07:14 PM
TOM MAR's Avatar
Try 1.29 firmware if you are using a newer version & or try another sensor cable
TOM MAR is offline
