will it work
Old 07-02-2013 | 02:48 PM
Default will it work
So I'm getting a turnigy battery and charger my question is the charger says any battery will work If it has a jst-hx adapter well my battery says it has a trx discharge plug.so will it work?sorry still learning..the charger is a accucell 6 turnigy thanks for all the help
XxX700XxX is offline
Old 07-02-2013 | 02:50 PM
Hoese37's Avatar
The XH adapter referrs to the balance connector.
Hoese37 is offline
Old 07-02-2013 | 02:55 PM
So I should be good?
Old 07-02-2013 | 03:28 PM
Dave_S's Avatar
You will be fine if you have jst-hx on battery, the turnigy batteries I have seen have jst-xh, if for some reason your don't you can get an adapter for cheap. The specs listed for battery your purchasing should say what kind of balance connector it has
Dave_S is offline
Old 07-02-2013 | 04:22 PM
OK so the turnigy battery I want it doesn't show in the picture a balance plug and doesn't say it has one? Is a balance plug a must have?
Old 07-02-2013 | 04:43 PM
Dave_S's Avatar
If its lipo it should have one, I don't know about 1s though, maybe some 1s don't have them? Is the battery lipo, life, nimh?
Dave_S is offline
Old 07-02-2013 | 04:45 PM
Its a 2s lipo 5800 mah turnigy
Old 07-02-2013 | 05:07 PM
mkiiina's Avatar
Post a link but it will come with one. If you have the bullet connectors it will have a harness with 3 bullets, 2 for positive and negative and 1 small one for balancing between the 2 cells.
mkiiina is offline
Old 07-02-2013 | 05:11 PM
Dave_S's Avatar
specs i found for that battery (if its the nano-tech) say its jst-xh
Dave_S is offline
Old 07-02-2013 | 05:24 PM
Yup its the nano tech one thanks for the help..before i order it should I do the 2s 5800 or 3s 3300? Right now with nihm I can hit about 35mph and I wanna at least be able to get in the 40mph range without changing my gearing.and what run time can I expect out of a 58002s and a 3300 3s
Old 07-02-2013 | 05:35 PM
http://www.hobbyking.com/hobbyking/s...cessories.html
http://www.hobbyking.com/hobbyking/s...mpatible_.html
http://www.hobbyking.com/hobbyking/s...er_Supply.html
Old 07-02-2013 | 05:37 PM
This is the setup i think I'm gonna go with..look OK for a first setup?
Old 07-02-2013 | 05:38 PM
Dave_S's Avatar
For that really would help to know motor kv and what have you, your best option would just search r/c calculations, were you can input your information, and it will tell you theoretical top speed based off of motor, gearing, voltage, tires and such not
Dave_S is offline
Old 07-02-2013 | 06:07 PM
I got a team associated rc10 t3 with a vxl system spur gear is 83 pinion is 23
Old 07-02-2013 | 06:36 PM
Dave_S's Avatar
If its vxl-3s your motor is 3500 kv, just plug numbers into here rc calculator, you can find in web search, I can't post link because I don't have enough posts.
Just cause I'm nice, I will help you out a bit. If you have stock t3 tires diameter is 3.75, gear ratio 2.6:1, 83 spur 21 pinion, assuming your tires don't balloon, at 4.2 vdc per cell with fresh charged 2s lipo your motor will be spinning about 30,000 rpms,your speed would theoretically be around 35 mph, if tires ballooned to 4" top speed would be about 37 mph, on 3s with tires not ballooning with same set-up theoretical top speed would be about 52 mph, but your motor will be spinning at about 44000 rpms, so it would be a good idea to keep an eye on the temp
Dave_S is offline
